VBA Project not Loading
rlester
rlester
I have a VBA project that will not load on my computer in Autocad 2021. I get the "Failed to load project from the file" error message. This same vba project is copied to other computers in my office and loads with no problems. What could be the problem?
Any help would be appreciated.
Rodney
CodeDing
@rlester ,
Do you have the VBA module installed?
Test with this real quick (copy/paste into command line)
(if (or (member "AcVba.arx" (arx)) (and (findfile "AcVba.arx") (arxload "AcVba.arx")))
  (alert "Good")
  (progn
    (alert "Bad/Missing, download VBA module and try again.")
    (startapp "explorer" "https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/download-the-microsoft-vba-module-for-autocad.html")
rlester
Yes. The VBA module is installed.
dlanorh
Is the project path in the "trustedpaths" system variable, the support file search path or the project files search path?
I am not one of the robots you're looking for
rlester
Yes. It is in the "Trusted Locations" and the "Support File Search Path"
Rodney
