Is plot transparency setting stored in named page setups?
JamesMaeding
Advisor Advisor
JamesMaeding
Hi All,
I read a few posts saying its stored as xdata on each layout.
Then, you have the PLOTTRANSPARENCYOVERRIDE variable.
I keep PLOTTRANSPARENCYOVERRIDE at 1, so from help:
"Uses the setting specified in the Page Setup or the Plot dialog boxes"
I agree checking the box works. You apply to layou, close, reopen plot dialog, its how you left it.
But, if I choose a named page setup, it unchecks.
That tells me, and the help says, its also in the named page setup.
Why do I care? I have tools that manipulate the named page setups so need to set that setting correctly.
I'll do some checking as I am starting to suspect the named page setup also has xdata with that setting.
Any help appreciated though.
thanks,
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
CodeDing
@JamesMaeding ,
My quick testing shows that, yes, the transparency is stored as XData on the page setup:
Now, with that being said, if  the user uses the "Plot" dialog box and they check/uncheck that box, it overrides the page setup and the transparency is stored as XData in the layout:
JamesMaeding
@CodeDing
Awesome.
Many thanks from MaeDing!
alteixeiraFTNE7
Observer
Observer
HI
I am a rookie. Can you help me access the  pagesetup ... and then access its Xdata
Alberto
CodeDing
@alteixeiraFTNE7 ,
This should be helpful enough to get you where you need.
It retrieves Named Page Setups, then displays their Plot Transparency state.
BUT REMEMBER (as I stated in my first message) :
@CodeDing wrote:
...if the user uses the "Plot" dialog box and they check/uncheck that box, it overrides the page setup and the transparency is stored as XData in the layout
Here's the code:
;; Retrieves Named Page Setups
;; Displays their Plot Transparency state
(defun c:TEST ( / dictPlotSettings psn psd namedPageSetups str eg plotTransparent)
  (setq dictPlotSettings (dictsearch (namedobjdict) "ACAD_PLOTSETTINGS"))
  (foreach item dictPlotSettings
    (cond
      ((= 3 (car item)) (setq psn (cdr item)))   ;; page setup name
      ((= 350 (car item)) (setq psd (cdr item))) ;; page setup dict
    );cond
    (if (and psn psd)
      (setq namedPageSetups (cons (cons psn psd) namedPageSetups) psn nil psd nil)
    );if
  );foreach
  (if (null namedPageSetups)
    (progn (prompt "\nNo Named Page Setups found.") (exit))
  );if
  ;; For the purposes of an example, I will select the FIRST named page setup
  ;; The 'namedPageSetups' list looks like this:
  ;; (("Page Setup A" . <dict-ename>) ("Page Setup B" . <dict-ename>) ...)
  (setq nps (car namedPageSetups))
  ;; Loop through named page setups
  (setq str "")
  (foreach nps namedPageSetups
    ;; get page setup with Extended Data for PLOTTRANSPARENCY
    (setq eg (entget (cdr nps) '("PLOTTRANSPARENCY")))
    ;; Retrieve Plot Transparency as bool
    (setq plotTransparent (not (zerop (cdr (assoc 1071 (cdadr (assoc -3 eg)))))))
    (setq str
      (strcat str
        "\nPlot Transparency for '" (car nps) "': " (if plotTransparent "ENABLED" "DISABLED")
      );strcat
    );setq
  );foreach
  (alert (princ str))
  (princ)
);defun
Screenshot of result:
Best,
~DD
