Is it possible to create new unique colour names?
Message 1 of 11
Hi.
I was just wondering if it would be possible to create a unique set of colours, and give them names that would show up in the colour control menu, similar to the existing, Blue, Red, Green etc? So for instance i wanted to hatch something like a footway in a specific RGB code, i could save that as 'Footway' and so on. something that i could use in across all my drawings without the need to allocate the RGB codes every time. Thanks in advance.
Steve.
Replies (10)
Message 2 of 11
cadffm
CAD beginner, or ?
Beginner:
Create a LAYER with that RGB color and if you like to draw a footway, usw the Layer "footway",
objectcolor should be "ByLayer"
Expert:
Yes you can create your own "colors", but i would never prefer to this.
And you can not edit the Color drop-down menu, you have to create your
own menu to set/change colors.
How to?
Create your own ColorBook to assign special rgb codes to  a (color)name.
More questions about this?
Only like some RGB-colors in the drop down menu?
USE the color one time in your program session, you will see these colors in the drop down menu then.
Sebastian
Message 3 of 11
Thank you Betreff. Im not a CAD beginner, but i'm certainly no expert. The reason i hadn't assigned the colour by layer, is that at times they are likely to be assigned to alternative layers. I will look into creating a custom palette in the colour book, i think this may be my best option, i just never really knew it existed if i'm honest.
Steve
Message 4 of 11
cadffm
Thank you Re. ( 😁 )
>"I will look into creating a custom palette in the colour book"
Whatever you like, buti  do not support it and it brings you no real benefit.
I think user defined "extra Button"  a lot more helpful, or working with the toolpalette.
Sebastian
Message 5 of 11
ВeekeeCZ
@Anonymous wrote:
Thank you Betreff...
@cadffm
Hey Betreff, how you doin? Ever considered to change your user name? So many people recognize you by this nick. And it happened so naturally.  Like it! 😜
Message 6 of 11
I fully appreciate your advice, but i don't understand what you mean by "Extra button, or working with Tool palette". However, looking at the colour book layout, if i could replicate that with my own names and RGB codes, this would be ideal for my needs. (See attachment)
Steve.
Message 7 of 11
cadffm
"Extra Button" means
such things with MenuMacro sequences, For example in side the Ribbon:
Toolpalette is this feature:
https://www.youtube.com/results?search_query=AutoCAD+Toolpalette
ColorBook
Again, i think just "Experts" should use custom color-books, but you asked for, so let's take a look.
https://forums.autodesk.com/t5/autocad-forum/color-book-editor/td-p/2447208
STOP!
We are not talking about AutoCAD? but MEP3D or CIVIL3D, or ACA?
then it is one more reason to not go this way.
Sebastian
Message 8 of 11
cadffm
@ВeekeeCZ  schrieb:
@cadffm
I like the idea 🤣
Sebastian
Message 9 of 11
Thanks again, all very much appreciated. I will have a look at these and see how i get on.
And yes, im referring to AutoCAD 2019.
Steve
Message 10 of 11
You're a legend. Ive just created a test color book, and this is going to be the perfect solution for me. (See attachment)
I cant thank you enough man.
Cheers
Steve
Message 11 of 11
cadffm
>"this is going to be the perfect solution for me"
And for others? And in the feature? I am not 100% sure
Test it with a small project side by side "as text", especially if there is data exchange with other companies!
Test also the printing of the plans etc.,
I can not explain everything to you in a few sentences, but it's not my job.
Sebastian
