Intersecting polylines to be select and Layer name to Label with same layer name
Hannan1
Message 1 of 14
Hannan1
Can any body help me in this causes ,
I want to select all polylines (or all entities Etc.) which is intersecting to selected Polyline,
And the Other thing is that
I want to Place a layer Name Lable on the Polyline with the same layer name Like Polyline layer should be lable layer name is this can be happen with multiple selection
For this any Lisp is there.
Replies (13)
Message 2 of 14
SeeMSixty7
Can you upload an image of before and after of what you are looking for?
Good luck,
Message 3 of 14
Hannan1
Message 4 of 14
Hannan1
Please check Before and After Screenshort Capture 2 file name attachedCapture 2.JPG
Message 5 of 14
Ranjit_Singh
Here's one example that might work for you.
;;Add layer names to lines/polylines
;;Ranjit Singh
;;5/11/17
(defun c:somefunc (/ curosmode vlaobj ent ss1) (setq curosmode (getvar 'osmode)) (setvar 'osmode 16384) (command "._zoom" "_obj" (setq ent (car (entsel "\nSelect intersecting polyline: "))) "") (mapcar '(lambda (x) (entmake (list '(0 . "MTEXT") '(100 . "AcDbEntity") (cons 8 (caddr x)) '(100 . "AcDbMText") (cons 10 (cadddr x)) (cons 1 (caddr x)) '(7 . "ROMANS") (cons 50 (car x)) '(71 . 8)))) (mapcar '(lambda (x) (setq vlaobj (vlax-ename->vla-object (car x))) (cons (angle '(0 0) (car (mapcar '(lambda (x) (if (minusp (car x)) (mapcar '* '(-1 -1) x) x)) (list (vlax-curve-getfirstderiv vlaobj (vlax-curve-getparamatpoint vlaobj (vlax-curve-getclosestpointto vlaobj (last x)))))))) x)) (mapcar '(lambda (x) (cons (cadr x) (cons (cdr (assoc 8 (entget (cadr x)))) (cdr (cadddr x))))) (vl-remove-if '(lambda (x) (equal ent (cadr x))) (ssnamex (setq ss1 (ssget "_f" (cdr (reverse (vl-remove-if-not 'listp (mapcar 'cdr (entget ent))))) '((0 . "*LINE"))))))))) (setvar 'osmode curosmode) (sssetfirst nil (ssdel ent ss1)) (princ))
Message 6 of 14
stevor
So Hannan1, did the c:somefunc of Ranjit work for you?
If not, for more suggestions,
post a simple DWG, small and old format.
S
Message 7 of 14
Hannan1
Its not working the Error is like ( Command: ; error: bad argument type: lselsetp nil )
Message 8 of 14
Hannan1
Please find the DWG sample file.
Message 9 of 14
Ranjit_Singh
Your lines are 2d polylines and I designed my program for line and lwpolyline. That's why you should always post a drawing 🙂 See updated code below. See the screencast.
(defun c:somefunc  (/ curosmode vlaobj ent ent2 etdata lst ss1)
 (setq etdata (entget (setq ent2 ent)))
 (cond ((= "POLYLINE" (cdr (assoc 0 etdata)))
        (while (/= "SEQEND" (cdr (assoc 0 (setq etdata (entget (setq ent (entnext ent)))))))
         (setq lst (cons (cdr (assoc 10 etdata)) lst))))
       ((wcmatch (cdr (assoc 0 etdata)) "LINE,LWPOLYLINE")
        (setq lst (cdr (reverse (vl-remove-if-not 'listp (mapcar 'cdr etdata))))))
       (t ()))
 (if lst
                    (cons (angle '(0 0)
                                 (car
                                             x))
                                          (list
                          x))
                          (vl-remove-if '(lambda (x) (equal ent2 (cadr x)))
                                        (ssnamex (setq ss1 (ssget "_f" lst '((0 . "*LINE"))))))))))
 (princ))
Message 10 of 14
Hannan1
Thank you very much Ranjit.Singh for this it was work for me .
But One more thinks is there Which is that i would like to select those polyline which is intersecting to the selected polyline.
Bcoz. i want to copy those lines tho new drawing file .
This Code i can accept solve .
Message 11 of 14
Ranjit_Singh
@Hannan1 wrote:
............ i would like to select those polyline which is intersecting to the selected polyline....
Change this line
to
(sssetfirst nil (ssdel ent2 ss1))
I cannot test it since I am away from my computer but I am pretty sure it will work. Give it a try. I will also check [tomorrow] if it works.
Message 12 of 14
Hannan1
Thank you very much Sir...
Its is work Very nice
Thanks thanks
Message 13 of 14
Ranjit_Singh
You are welcome 🙂
Message 14 of 14
Hannan1
One more help Plz,,
If i want Add vertex on intersecting points in selected polyline.
