Installing AutoCAD AutoLISP Ext and Running VS Code both fail
hencoop
Advisor Advisor
hencoop
I set LISPSYS = 1, restarted AutoCAD, and then ran VLIDE (and subsequently VLISP).
I keep getting this in response to both commands:
Installing the AutoCAD AutoLISP extension. This might take a moment.
Command:
Command: AutoCAD AutoLISP extension has been installed and Visual Studio Code is starting.
However, Visual Studio Code is NOT started. (It is installed on my system and runs independently of AutoCAD).
I installed the AutoCAD AutoLISP Extension from within VS Code after several the AutoCAD failures to get it done.
Still, the only response I get from AutoCAD remains unchanged and is in the code block above.
Does anyone know why this isn't working?
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
hencoop
Okay, I uninstalled and reinstalled Microsoft Visual Studio Code.  Then I enabled the AutoCAD AutoLISP Extension.
The AutoCAD VLISP command opened VS Code as expected.
Old school solution to programs not working worked!
