Installing AutoCAD AutoLISP Ext and Running VS Code both fail
hencoop
Advisor Advisor
hencoop
I set LISPSYS = 1, restarted AutoCAD, and then ran VLIDE (and subsequently VLISP).
I keep getting this in response to both commands:
Installing the AutoCAD AutoLISP extension. This might take a moment.
Command:
Command: AutoCAD AutoLISP extension has been installed and Visual Studio Code is starting.
However, Visual Studio Code is NOT started. (It is installed on my system and runs independently of AutoCAD).
I installed the AutoCAD AutoLISP Extension from within VS Code after several the AutoCAD failures to get it done.
Still, the only response I get from AutoCAD remains unchanged and is in the code block above.
Does anyone know why this isn't working?
Henry C. Francis
Authorized Autodesk Developer
Civil Design Specialist – Water & Wastewater Infrastructure
hencoop
Okay, I uninstalled and reinstalled Microsoft Visual Studio Code.  Then I enabled the AutoCAD AutoLISP Extension.
The AutoCAD VLISP command opened VS Code as expected.
Old school solution to programs not working worked!
Henry C. Francis
