Inserting Block using LISP and Specifying Coordinates
charlesc32LT75X
charlesc32LT75X
Within Autocad, I'm looking for the code which will insert a block into a drawing using lisp and specifying the coordinates. I don't want to have to select the Blocks location manually.
Any ideas?
Thank you in advance,
Charles C
paullimapa
assum'g the following:
Name of block = Down
Insert coordinates: 0,0,0
Insert scale = 1
Insert Rotation = 0
(vl-cmdf"_.Insert""Down""0,0,0""1""0")
Paul Li
IT Specialist
@The Office
Kent1Cooper
... and that the Block is defined for uniform scaling.  If not, add another "1" [between the "1" and the "0"] for the Y scale factor.
Kent Cooper, AIA
charlesc32LT75X
The solution, including the extra "1", worked perfectly. Thank you both for your input.
Take care.
Charles
Sea-Haven
Another sets scale before selecting insert point. Note if block has attributes need to either turn off add values using Attreq or add all values for the matching attributes "" is ok for blank entry.
(command "-insert" blkname "s" 1 pt 0.0)
