Inserting a Drawing Without Knowing the Source Drawings Units
mgorecki
mgorecki
I'm writing a program that will insert a selected drawing into the new drawing.  The new drawing will always have insunits set to 4 (millimeters).  I have no idea what the drawings to be inserted scale could be.  Others will be using this program and I have no idea what drawings they'll select to insert.
Is there a way to always insert the drawings so they come in scaled in mm?
Moshe-A
@mgorecki  hi,
You can inspect the insunits of the drawing to be inserted with the following (openFileDBX) function.
moshe
(defun openFileDBX (dbxFile / dbxOpen)
    (if (setq dbxOpen
            (vlax-create-object
                (strcat    "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2) )
        (if (vl-catch-all-apply 'vla-open (list dbxOpen dbxFile))
            (not (vlax-release-object dbxOpen))
            dbxOpen
        (princ "\nUnable to create object")
cadffm
@Moshe-A
With odbx? Can you post a working sample please if you are not wrong, thx.
@mgorecki
And dont forget insunitsdefsource insunitsdeftarget and aec units (if important for your case)
Sebastian
