Insert text at coordinates from excel
Message 1 of 11
Hi
I have an excel file that I have the X,Y,Z coordinates of a pipeline and I need to insert some text also contained in the excel file at these coordinates. Is there any way to insert a leader at the coordinate and use the text in the excel file as the leader text? I have over 1000 of these points to do. I'm not very familiar with LISP files so that may be too difficult for me. Even if i could just insert the text at the coordinates that would be better than having to insert each one individually. Any help appreciated
Replies (10)
Message 2 of 11
dbhunia
can you send the excel
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 11
cadffm
@Anonymous
without Lisp check out your steps in commandline to create an mleader,
then built an script und start the scriptfile.scr with command SCRIPT.
Sample attached, this works with a Standard dwg(no template or just  acad.dwt)
Sebastian
Message 4 of 11
dbhunia
@Anonymous wrote:
Hi
If your Excel is like this format
Then go through the attached code....
Another thing Keep the Excel file close.
And for Leader what should be its direction?
Debashis Bhunia
Message 5 of 11
dbhunia
@Anonymous wrote:
Hi
Another things-
1. Keep the Excel file close.
2. If your Excel file contains any text in first row, like
Then make change in the line, from - (setq address "A1:D50000")  To (setq address "A2:D50000")
Debashis Bhunia
Message 6 of 11
Thanks. This worked perfectly
Message 7 of 11
Hi. I'm looking for the same thing but in some cells I have a single line text and in some cells I have a multiline text. For example Screen Shot 04-02-19 002.PNG
Is there a way to insert multiline text? I'm trying to find it but I can't.
A long time ago I found somewhere you could copy a line from notepad to command line where you wrote
command, first corner, second corner, text
mtext 100,100 200,200 ......
but i forgot how to write the command for text. do you have to use quation marks or what. does anyone have an idea?
Message 8 of 11
Thank q very much . It help me lot i mean it.
Message 9 of 11
Can you explain how to use this?
Message 10 of 11
how to use this?
Message 11 of 11
ivoitiuk
How to insert multiline text the same way as in example?
