insert space to multiple text and mtext
mruPRQUJ
Message 1 of 28
mruPRQUJ
Could you please write a lisp to insert space to multiple text and mtext? The space could be 3 time or 15 times letter width? Please see the image below, insert 10 times width of letter space before 1X, 2X, 3X,4X,5X and 1Y, 2Y, 3Y, 4Y 5Y, Thank you very much in advance. šŸ™‚
Replies (27)
Message 2 of 28
Moshe-A
@mruPRQUJ  hi,
Here is a nice function that will make your life better šŸ˜€
usage:
(white_spaces 10 "Mi" "Michael Ru") return => "          Michael Ru"
or
(white_spaces 3 "ha" "Michael Ru") return => "Mic   hael Ru"
works?
Moshe
;; insert white spaces inside string
;; size    - [int]    the requied length of white space
;; pattern - [string] the pattern to serach in string, white spaces is insert before
;; string  - [string] the string to be modified
;; return the combined string or nil if pattern not found
(defun white_spaces (size pattern string / p ch)
 (if (setq p (vl-string-search pattern string))
  (strcat (substr string 1 p) (progn (setq ch "") (repeat size (setq ch (strcat ch " ")))) (substr string (1+ p)))
 ); if
); white_spaces
Message 3 of 28
mruPRQUJ
Hi, the function (usage) are great! Could you please advise me how to add the usage (function) to the lisp? I can't thank you enough šŸ™‚
or
Message 4 of 28
Moshe-A
@mruPRQUJ
Good Morning,
Have this story:
You are on business trip from work out of town and a rookie co-worker email you that he need your help on a design you are working (Huston we have a problem šŸ˜€) you are the only one that can help him. you have your laptop with AutoCAD installed.
How do you thing you can help him, what are the options?
still thinking how is this related to this thread, think again.
Message 5 of 28
mruPRQUJ
Hi, please see attached CAD file, thanks a million. šŸ™‚
Message 6 of 28
Moshe-A
@mruPRQUJ
Nice to see that you quickly got the message hope next time you will be posting it as you open the thread (as i can recall you're been here for some time, maybe for some months and you already knows how this all works šŸ˜€)
so i saw the dwg and i do not understand where the spaces is to be insert i thought insert space in a middle of a text but from the dwg it's all sum with moving texts?
maybe a better sample of the state before and after will clear that?!
Moshe
Message 7 of 28
mruPRQUJ
Sorry, I did not say it clearly. You are right, this time is to sum moving text before 1X, 2X, 3X,4X,5X and 1Y, 2Y, 3Y, 4Y 5Y. Maybe I need to create another post  for inserting space before 1X, 2X, 3X,4X,5X and 1Y, 2Y, 3Y, 4Y 5Y.  I need this one as well for different project,  thank you very much! šŸ™‚
Message 8 of 28
Moshe-A
no don't create another thread, just post the sample dwg with the state before and after
Message 9 of 28
komondormrex
hey,
check the following.
(defun c:insert_nth_space (/ 20_space_string mtext_ename_list mtext_value change_pos pattern_found)
	(setq 20_space_string (vl-list->string '(32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32))
	      mtext_ename_list (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "*text") (1 . "*[12345][XY]*"))))))
  	(foreach mtext mtext_ename_list
		(setq mtext_value (cdr (assoc 1 (entget mtext))))
  		(vl-some '(lambda (pattern) (setq change_pos (vl-string-search pattern mtext_value)))
			  '("1X" "2X" "3X" "4X" "5X" "1Y" "2Y" "3Y" "4Y" "5Y")
	  	(setq pattern_found (substr mtext_value change_pos 2)
	  	      mtext_value (vl-string-subst (strcat (substr 20_space_string 1 10) pattern_found) pattern_found mtext_value)
	  	(entmod (subst (cons 1 mtext_value) (assoc 1 (entget mtext)) (entget mtext)))
  	(princ)
Message 10 of 28
mruPRQUJ
Could you please advise me if it works on both text and mtext? how to adjust space width? thanks.
Message 11 of 28
komondormrex
check update on ssget filter above.
Message 12 of 28
mruPRQUJ
Hi, the lisp is great! I tried it, but I did not know how to change width space. Could you please provide some advice to me? Thanks a lot! šŸ™‚
Message 13 of 28
komondormrex
hi, there it is.
10 is the number of spaces.
Message 14 of 28
mruPRQUJ
Thanks a million!
Message 15 of 28
mruPRQUJ
Hi, white space is also useful for different project. Is it possible to use the same  DWG and insert 10 space before 1X, 2X, 3X, 4X, 5X, 3 space before 1Y, 2Y, 3Y,4Y, 5Y. I can’t thank you enough.
Message 16 of 28
komondormrex
hi,
sure.
check the code following.
	  	(setq pattern_found (substr mtext_value (1+ change_pos) 2)
	  	      mtext_value (vl-string-subst (strcat (substr 20_space_string 1 (if (wcmatch pattern_found "*X") 10 3)) pattern_found) pattern_found mtext_value)
  	(princ)
Message 17 of 28
Moshe-A
@mruPRQUJ  hi,
As you request, here is my version that uses (white_spaces) function. it is mush longer then the other solution you already have but very VisualLISP style structured šŸ˜€
first lets put things accurately:
your request was to insert spaces before 1X, 2X, 3X,4X,5X and 1Y, 2Y, 3Y, 4Y 5Y - yes?
but the sample drawing you post show that one space is already in text so i think the key text to find here is:
" 1X" " 2X" " 3X" " 4X" " 5X"  etc
i assume the text is coming from other lisp -   am i right?!
lines 119-127, the program contains 2 commands:
1. PUSHSPC (push white spaces).
2. CONDSPC (condense white spaces) if you made a mistake or just want to revert back,  this is the command.
    selected texts must have at least two spaces before the key in order to be processed by this command.
line 91 declares:
(setq SPACES '(("X" . 10) ("Y" . 3)))
it defines the size of spaces for the X and Y. if you want something else, change these numbers.
enjoy
Moshe
(vl-load-com) ; load activex support
(defun spc:main (cmd / _dataKeys  white_spaces push_white_spaces condense_white_spaces ; local functions
		       SPACES adoc ctr AcDbEntity value)
 ; Anonymous function
 (setq _dataKeys (lambda () (mapcar (function (lambda (ch) (mapcar (function (lambda (n) (strcat " " (itoa n) ch))) '(1 2 3 4 5)))) '("X" "Y"))))
 (defun white_spaces (size pattern string / p s)
  (if (setq p (vl-string-search (strcase pattern) (strcase string)))
   (strcat (substr string 1 p) (progn (setq s "") (repeat size (setq s (strcat s " ")))) (substr string (1+ p)))
  ); if
 ); white_spaces
 ; Return T if text has the "key" + at lease extra one space
 (setq _hasWhiteSpace (lambda (s) (vl-some (function (lambda (item) (vl-some (function (lambda (key) (vl-string-search (strcat " " key) s))) item))) (_dataKeys))))
 (defun push_white_spaces ()
  (vl-some
    (function
     (lambda (item)
       (vl-some
         (function
	   (lambda (key / dp nValue)
            (if (setq dp (assoc (substr key 3 1) SPACES))
             (if (setq nValue (white_spaces (cdr dp) key value))
	      (progn
               (vla-put-textString AcDbEntity nValue)
	       (setq ctr (1+ ctr))
	      ); progn
             ); if
            ); if
	   ); lambda
	 ); function
         item
       ); vl-some
     ); lambda
    ); function
    (_dataKeys)
  ); vl-some
 ); push_white_spaces
 ; condense texts, remove white spaces from text
 (defun condense_white_spaces ()
  (if (_hasWhiteSpace value)
   (vl-some
     (function
       (lambda (item)
         (vl-some
           (function
	     (lambda (key / i ch nValue)
	      (if (vl-string-search key value)
	       (progn
    	        (setq i 0 nValue "")
                (repeat (strlen value)
                 (setq i (1+ i) ch (substr value i 1))
                 (cond
                  ((and
	             (eq ch " ")
	             (eq (substr value i 3) key)
                   (setq nValue (strcat nValue ch))
	          ); case
	          ((/= ch " ")
	          ); case
	         ); cond
	        ); repeat
	        (setq ctr (1+ ctr))
	       ); progn
	      ); if
	     ); lambda
	   ); function
	   item
	 ); vl-some
       ); lambda
     ); function
     (_dataKeys)
   ); vl-some
  ); if
 ); condense_white_spaces
 ; here start spc:main
 (setq SPACES '(("X" . 10) ("Y" . 3)))  ; dotted pair
 (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
 (vla-startundomark adoc)
 (setq ctr 0)
 (if (ssget '((0 . "text,mtext") (1 . "*[ ][12345][XY]*")))
  (progn
   (vlax-for AcDbEntity (vla-get-activeselectionset adoc)
    (setq value (vla-get-textString AcDbEntity))
    (cond
     ((eq cmd 'PUSH)
      (push_white_spaces)
      (princ (strcat "\n" (itoa ctr) " text(s) pushed."))
     ); case
     ((eq cmd 'CONDENSE)
      (condense_white_spaces)
      (princ (strcat "\n" (itoa ctr) " text(s) condensed."))
     ); case
    ); cond
    (vlax-release-object AcDbEntity)
   ); vlax-for
  ); progn
 ); if
 (vla-endundomark adoc)
 (vlax-release-object adoc)
 (princ)
); spc:main
; push white spaces in texts
(defun c:pushSpc ()
 (spc:main 'PUSH)
; condense white spaces from texts
(defun c:condSpc ()
 (spc:main 'CONDENSE)
Message 18 of 28
Moshe-A
@mruPRQUJ ,
Good Morning, fixed a bug šŸ¤£
Moshe
Message 19 of 28
mruPRQUJ
Hi, I am really sorry to reply to you so late, as I am tied up with my work. I will test it later, thank you very much! šŸ™‚
Message 20 of 28
Moshe-A
@mruPRQUJ  hi,
What's the test result?
