Insert dynamic block between 2 points
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi forum,
I have a dynamic block(see block 'inspection - member rating' block in attached template file. I use this to illustrate inspection data of steel members shown on a pdf drawing xref. I also use the completed inspection drawing to extract the data into excel.
The block mainly consists of a line with an equal stretch parameter on either end. Currently I have to enter the block at the center of the member i want to markup and then stretch the line to the extents of the member. I would like some direction into being able (perhaps through lisp?) to click between the two points where I want the block to be placed(either end of member).
Also, (if you happen to be having a good day) the block contains a few fields, I would like the layer of the block to change automatically based on the value entered in the 'rating' field of the block. (layers are color coded based on rating of member)
Finally,(if you're having an even better day) it would be great if I can use this on a tablet in the field, is there anyway to change the interface of field entry to something that is more touch-friendly (perhaps a dialogue box with buttons or radio buttons to pick validated entries for the block)
By all means not expecting the complete solution handed over but any pointers would be very helpful.
Thanks in advance
