Insert block on current layer
David_Prontnicki
Message 1 of 10
David_Prontnicki
I have the lisp below to insert a symbol, what I cant figure out is how to get the block to insert on whatever the current layer is. Currently it comes in on the layer of the block. I would like to leave all blocks on layer 0 (Zero) in their respective drawings, and have them insert in working drawing on whatever the current layer is set to.
(defun c:symbolsevergreens ()
  (command "insert" "PATH/Evergreens.dwg" (getpoint "\nSelect insertion point: ")
    "1" "1" "0" ) (command "explode" "last")
  (princ)
Any help would be greatly appreciated.
Replies (9)
Message 2 of 10
ВeekeeCZ
  (command "insert" "PATH/Evergreens.dwg" (getpoint "\nSelect insertion point: ") "1" "1" "0" )
  (command "_.chprop" "_L" "" "_Layer" (getvar 'clayer) "")
  (command "_.chprop" "_P" "" "_Layer" (getvar 'clayer) "")
  (princ)
 Probably the blue one.
Message 3 of 10
David_Prontnicki
Thank you BeeKeeCZ,
I was close, I had tried that but my syntax was off. Was using "LAST" instead of "_L".
Also I had to change the order of operations. I had to move the change prop AFTER the EXPLODE. Not exactly sure why but I think it has to do with the explode. they explode to layer 0 so...
Edit: I just saw that you said prob blue one. It's been one of those days. 🙂 Any benefit to using _P vs. _L?
  (princ)
This seems to work. Do you see anything wrong with this, any potential issues?
Message 4 of 10
ВeekeeCZ
Yes, I found it too - and edited.
I didn't know how many objects you have within the file. Change the letter if you have more than one object inside, from _L (or your Last) to _P as previous.
Also your first line could be changed to:
(command "insert" "PATH/Evergreens.dwg" PAUSE 1 1 0)
Message 5 of 10
David_Prontnicki
So if I'm understanding you correctly if my "Evergreen.dwg" drawing file that I am inserting only has one (1) item use "_L". If it has multiple items use "_P".
So I am inserting a single dynamic block, the evergreen.dwg has one dynamic block in it so i will be using "_L", correct?
Thank you!
Message 6 of 10
Kent1Cooper
Thank you!
I would use P in any case.  Whenever you EXPLODE something, the resulting pieces, however many there are, become the Previous selection set, so P would cover any possible number of pieces in whatever is EXPLODEd, and you wouldn't have to re-write the routine if you changed the contents of the Inserted drawing to more than one thing.
Kent Cooper, AIA
Message 7 of 10
ВeekeeCZ
First of all, you should export your dynblock using the WBLOCK command. That way you won't have a block within a file, that inserted is a block within a block which has to be exploded. If you use wblock, that way is would be just a geometry inside a file. That inserted will be just a block without a need be exploded.
Message 8 of 10
David_Prontnicki
That makes a lot of sense. Thank you!
Message 9 of 10
David_Prontnicki
That also makes a lot of sense. Thank you!
Message 10 of 10
ВeekeeCZ
...but if you redefine your block/file, then you find that "_P" is not working for your Layer change. You will need to get "_L" back 😉
