Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a lisp that allow us to pick a block and insert it at selected line endpoint? see attached.
check this, replace "YourBlockName" with your block name, ESC to stop the command
(defun c:mins ()
(while t
(command "insert" "YourBlockName" "_endp" pause 1 1 0)
enjoy
Moshe
Thanks for your reply, but what I need is that the routine asks me to select the block in order to get its name so that the lisp would me more general, second I want the lisp to ask me to select the lines and then to insert the block automatically at each line endpoint.
@a.tawkXHKN6 wrote:Thanks for your reply, but what I need is that the routine asks me to select the block in order to get its name so that the lisp would me more general
put the word pause instead of "YourBlockName"
what's the difference if you select the line or pick it's endpoint?
Which endpoint -- the start or the end? If not always the same end, how would the routine know which end to use unless they are selected individually? If that's the case, the ENDpoint pick approach should be as good as selecting the Lines. If always the same end, then you could select multiple Lines, such as in a window, but how will you know where it's going to put the Blocks? You can't tell by looking on-screen which end of a Line is which.
(defun c:InTheEnd ( / e blkName i el)
(if (and
(princ "\nSelect BLock")
(setq e (ssget "_+.:S:E" '((0 . "INSERT"))))
(setq blkName (getpropertyvalue
(setq e (ssname e 0))
"BlockTableRecord/Name"
(setq Lines (ssget '((0 . "LINE"))))
(progn
(repeat (setq i (sslength Lines))
(setq el (ssname Lines (setq i (1- i))))
(entmakex (list (cons 0 "INSERT")
(cons 2 blkName)
(cons 10 (vlax-curve-getEndPoint el))
(princ)
Depending on how the lines were created , the "Endpoint" might not be what you expected.
We can add an option to see where the block will be inserted and prompt the user to relocated the block.
HTH
I just need the block to be insert at the opposite lower side of the line not the upper.
Thank you.
Thank you.
(if (and
(progn
(setq data (list (vlax-curve-getEndPoint el) (vlax-curve-getStartPoint el)))
(cons 2 blkName)
(cons 10
(if (> (cadar data)(cadadr data))
(cadr data)(Car data))
(princ)
HTH
here is your ultimate solution 😀
IBCE command, starts with request for block name and than Select objects: ... use the "fence" method to select the lines (you also can select plines even splines) the block would be insert at closest endpoint of the line crossing the fence line.
enjoy
Moshe
(vl-load-com) ; load activex support
; IBCE - Insert Block at Close End
(defun c:ibce (/ get_block_name retrieve_fence_data ; local functions
bname ss ename dX dS dE pS pE)
(defun get_block_name (/ bn)
(while (not
(and
(/= (setq bn (getstring "\nBlock name: ")) "")
(or
(tblsearch "block" bn)
(findfile (strcat bn ".dwg"))
(vlr-beep-reaction)
(prompt (strcat "\nBlock " bn " is not exist."))
); while
bn
); get_block_name
(defun retrieve_fence_data (/ fence-data)
(defun fence-data ()
(vl-remove-if
'not
(mapcar
'(lambda (x)
(if (= (car x) 4) ; fence selection
(cons (cadr x) (list (cadr (last x))))
); lambda
(ssnamex ss)
); mapcra
); vl-remove-if
);fence-data
(cond
((fence-data))
( t
(vlr-beep-reaction)
(prompt "\nRequires Fence method selection.")
); cond
); retrieve_fence_selection
; here start C:IBCE
(setvar "cmdecho" 0)
(command "._undo" "_begin")
(if (and
(setq bname (get_block_name))
(setq ss (ssget '((0 . "*line")))) ; select by "fence" only
(foreach item (retrieve_fence_data)
(setq ename (car item))
(setq dX (vlax-curve-getDistAtPoint ename (vlax-curve-getClosestPointTo ename (cadr item))))
(setq dS (vlax-curve-getDistAtPoint ename (setq pS (vlax-curve-getStartPoint ename))))
(setq dE (vlax-curve-getDistAtPoint ename (setq pE (vlax-curve-getEndPoint ename))))
(command "._insert" bname (if (< (- dX dS) (- dE dX)) pS pE) 1 1 0)
); foreach
); if
(command "._undo" "_end")
(setvar "cmdecho" 1)
(princ)
); c:ibce
(defun c:InTheEnd ( / Thisblocks spc e blkName i ent el fnSTR StrDIA)
(defun Thisblocks ( / a LocalB)
(while (setq a (tblnext "Block" (null a)))
(if (and
(/= 4 (logand 4 (cdr (assoc 70 a))))
(/= (substr (setq bn (cdr (assoc 2 a))) 1 1) "*"))
(setq LocalB (cons (cdr (assoc 2 a)) LocalB)))
LocalB
(setq spc (vlax-get (vla-get-ActiveLayout
(vla-get-activedocument(vlax-get-acad-object))) 'Block))
(if (and
(progn
(initget "N")
(setq ent (entsel "\nSelect block/ N for name: "))
(setq blkName
(cond
( (and
(eq ent "N")
(setq lst (Thisblocks)))
(setq StrDiaFnme (vl-filename-mktemp "tmp.DCL"))
(setq fnSTR (open StrDiaFnme "w"))
(write-line
"dcl_settings : default_dcl_settings { audit_level = 3; }
ListOfTags : dialog
{ label = \"Select Tag(s)\";
: list_box { key = \"TagList\";
width = 8.0; height = 10.0; } spacer ;
ok_cancel; }" fnSTR)
(close fnSTR)
(setq StrDIA (load_dialog StrDiaFnme))
(if (not (new_dialog "ListOfTags" StrDIA))
(exit)
(start_list "TagList")
(mapcar 'add_list Lst)
(end_list)
(action_tile "TagList" "(setq dd (get_tile \"TagList\"))")
(action_tile "accept" "(done_dialog 1)")
(action_tile "cancel" "(done_dialog 0)")
(start_dialog)
(unload_dialog StrDIA)
(vl-file-delete StrDiaFnme)
(nth (atoi dd) lst)
( (and (setq e (car ent))
(eq (cdr (Assoc 0 (entget e))) "INSERT"))
(getpropertyvalue e "BlockTableRecord/Name")
(print blkName)
(princ "\nSelect object(s) for block insertion")
(setq Lines (ssget '((0 . "ARC,*LINE"))))
(progn
(vlax-invoke spc 'InsertBlock (if (> (cadar data)(cadadr data))
blkName 1 1 1 0)
(princ "\nInvalid or null selection"))
(princ)
