Insert Block at Coordinates
anieves228
anieves228
Hello all,
Im at a loss here. I did a lisp to insert a PE seat at a specific coordinate, it does not register the Y coordinate. Im not sure what happened because  I have used this method in the past. It registers the X coordinate but it puts the Y coordinate at 1.556. I have changed the Y to several different values but doesn't change unless I put 3 or more.
	(DEFUN C:APDMS ()
		(SETVAR "CMDECHO" 1)
			(COMMAND "-LAYER" "M" "DWG-SEAL" "L" "CONTINUOUS" "" "LW" "0" "" "S" "0" "")					;SEAL LAYER
			(SETVAR "CLAYER" "DWG-SEAL")
			(COMMAND
				"-INSERT"
				"Z:/Shared/zCAD/Automation/Seals/Derek Meyers - SEAL.DWG"
				(LIST 29.7 2.5)
				"1"
				"1"
				"0"
			(command "explode" "last")
		(PROMPT "\n AUTOPLACED DEREK MEYERS SEAL \n")
		(PRINC)
paullimapa
What if you set osmode to 0 and then try again?
Paul Li
IT Specialist
@The Office
anieves228
That worked!
The question I have now is why?
DGCSCAD
I've had a similar issue that was throwing off insertion points, but only on certain users PC's. After comparing each list of system variables, I found the culprit to be that OSNAPCOORD was set to 2 on some of them.
Setting  it to 1 smoothed it out:
(setvar "OSNAPCOORD" 1)
AutoCad 2018 (full)
Win 11 Pro
paullimapa
When you have running object snaps set the insert command will look for the closest effective osnap.
Paul Li
IT Specialist
@The Office
paullimapa
To add to @DGCSCAD  post read up on this
Paul Li
IT Specialist
@The Office
ec-cad
You can get around how the user's machine is setup for OSnaps.
Key is in system variable 'OSMODE
Top of your Lisp, do:
(setq OSM (getvar 'OSMODE))
(setvar 'OSMODE 0)
---- your remaining code
Then, at bottom before exit, do:
(setvar 'OSMODE OSM)
ECCAD
