Insert a block on a 3D position
Gdtech-Autocad
Message 1 of 11
Gdtech-Autocad
Hello
A drawing contains a block. I want to insert another block at the same position and rotation angle of this block using AutoLisp. It very seems simple no ?
When I make LIST of this entity I get the Insertion point:  X = 200.0000  Y = 100.0000  Z = 300.0000 which are the coordinates relative to the World UCS. The Rotation is 90°
I get the insertion point using Autolisp :
(setq ent(entsel "\n Select an entity: ")) ;- Let the user select a block
(setq en(car ent))                         ;- Get the entity name of the block
(setq enlist(entget en))                   ;- Get the DXF group codes
(princ "\n Entity DXF codes : ")(princ enlist)
I get this :
Entity DXF codes : ((-1 . <Entity name: b9c47cb0>) (0 . INSERT) (5 . 424) (330 . <Entity name: a6540540>) (100 . AcDbEntity) (67 . 0) (410 . Model) (8 . 0) (100 . AcDbBlockReference) (2 . TE_DN150_P) (10 -100.000 300.000 -200.000) (41 . 1.00000) (42 . 1.00000) (43 . 1.00000) (50 . 1.57080) (70 . 1) (71 . 1) (44 . 0.E+00) (45 . 0.E+00) (210 -1.00000 0.E+00 0.E+00))
To get the insertion point
(setq po(cdr (assoc 10 enlist)))
(princ "\n Insertion point: ")(princ po)
The result is -100.000 300.000 -200.000
If I use the INSERT command to insert another block at this position it will be wrong.
Use the trans function perhaps ?
(setq pt (trans po 0 1))
(princ "\n Corrected insertion point: ")(princ pt)
The result is still the same : -100.000 300.000 -200.000
Of course, I know, the problem is between to keyboard and the seat ….
My question : how can I get the right insertion point and rotation angle to INSERT a new block at the same location ?
Thanks for your help.
Replies (10)
Message 2 of 11
paullimapa
should work...could you share the dwg including the block you want to insert?
Paul Li
IT Specialist
@The Office
Message 3 of 11
Gdtech-Autocad
Hello
Thanks a lot for your response.
This is the file containing the block.
The corrected insertion point is not correct with this code :
(defun c:RPB()
  (princ "\n Entity name : ")(princ en)
  (setq bn (cdr(assoc 2 enlist)))
  (princ "\n Block name: ")(princ bn)
  (setq pt (trans po 1 0))
  (princ "\n Corrected insertion point : ")(princ pt)
Message 4 of 11
paullimapa
looks like when the block object has been rotated in any of the other axis (x, y or z), then this code is no longer correct to get the insertion point:
(setq po(cdr(assoc 10(entget(car(entsel))))))
so you can use the following code to check the normx, normy & normz values to see if they're other than +0:
(setq en(car(entsel))) ; select entity
(setq normx (getpropertyvalue en "Normal/X") normy (getpropertyvalue en "Normal/Y") normz (getpropertyvalue en "Normal/Z")) ; get normal
or just always use the following code to get the insertion point regardless of normal x, y, z:
(setq po(list (getpropertyvalue en "Position/X") (getpropertyvalue en "Position/Y") (getpropertyvalue en "Position/Z"))) ; get insert point
if you're interested, the vl method is this:
(vl-load-com)
(setq obj (vlax-ename->vla-object (car(entsel)))) ; select entity and convert to vl obj
(setq norm (vlax-safearray->list (vlax-variant-value (vla-get-Normal obj))))
(setq normx (car norm) normy (cadr norm) normz (caddr norm)) ; get the normal x,y,z
(setq po(vlax-safearray->list (variant-value (vla-get-InsertionPoint obj)))) ; get insert point
Paul Li
IT Specialist
@The Office
Message 5 of 11
hmsilva
@Gdtech-Autocad INSERTS DXF 10 are in OCS.
To get the coordenates in WCS, change:
to
(setq pt (trans po (car ent) 0))
Hope this helps,
Henrique
Message 6 of 11
Gdtech-Autocad
Hello thanks for your help ! This is working :
The point pt is correct ! fantastic.
I would like to insert a new block at the same position and rotation of the original block. With the code below, the new block is inserted at the right position but not correctly rotated.
(defun c:RPB()
  (setq po(cdr (assoc 10 enlist))) ; OCS insertion point
  (setq pt (trans po (car ent) 0)) ; WCS insertion point
  (princ "\n WCS insertion point : ")(princ pt)
  (setq rt(cdr (assoc 50 enlist))) ; rotation angle
  (setq rd (* rt (/ 180.0 pi)))
  (princ "\n rotation angle : ")(princ rd)
  (setq nb "TE_DN150_V") ; new block to insert
  (command "INSERT" nb pt "1" "1" rd)
Thanks for your time
Message 7 of 11
ВeekeeCZ
If are all properties the same but the blockname, you can simply rename it.
(vla-put-name (vlax-ename->vla-object (car (entsel "Old:"))) (cdr (assoc 2 (entget (car (entsel "New:"))))))
See  THIS recent thread.
Message 8 of 11
Gdtech-Autocad
yes there is also the BLOCKREPLACE command.
But in this case I want to add a new block, not replace the existing one.
Message 9 of 11
ВeekeeCZ
Well, that's a pretty similar job to do - just 3 letters difference.
(defun c:bladd ( / e d n)
  (if (and (setq e (car (entsel "\nOld: ")))
	   (setq d (entget e))
	   (setq n (car (entsel "\nNew: ")))
    (entmake (subst (assoc 2 (entget n)) (assoc 2 d) d)))
  (princ)
(defun c:blrep ( / e d n)
	   (setq d (entget e))
    (entmod (subst (assoc 2 (entget n)) (assoc 2 d) d)))
  (princ)
Message 10 of 11
Gdtech-Autocad
That's another way to proceed. And it works fine ! Thank you
To go further the idea is:
in the drawing select all blocks which have the name "TE_DN150_P"
at each position of these blocks (but on another layer) insert the block "TE_DN150_V" which is not in the drawing but must be inserted from the disk. This is the code that must be adapted. I suppose that the block must first be inserted in the drawing with the INSERT COMMAND. And then I do no know how to do...
(defun c:rab ()
  (setq nbn ("c:\\_DATA\\Bib\\TE_DN150_V")) ; new block name
  (setq sset (ssget "X" (list '(0 . "INSERT") '(2 . "*"))))
  (setq ne (sslength sset))
  (princ "\n====== Objects selected : ")(princ ne)
  (setq index 0)
  (while (< index ne)
    (setq ent (ssname sset index))
    (setq e (entget ent))
    (command "INSERT" nbn "0,0" "" "" "") ; first insert block from the disk
    (command "erase" "L" "") ; erase the inserted block
    ; missing code....
    (setq index (+ 1 index))
Message 11 of 11
ВeekeeCZ
What this note means: but on another layer
If you don't want to change the layer, you can use this
(defun c:bladda ( / o n p i s)
  (setq o "TE_DN150_P"
	n "TE_DN150_V"
	p "c:\\_DATA\\Bib\\")
  (or (tblsearch "block" n)
      (progn (command "_.-insert" (strcat p n)) (command)))
  (if (setq s (ssget "X" (list '(0 . "INSERT") (cons 2 o))))
    (repeat (setq i (sslength s))
      (entmake (subst (cons 2 n) (cons 2 o) (entget (ssname s (setq i (1- i))))))))
  (princ)
