Incrementing variables in while loop
Message 1 of 8
Hi Autodesk Community,
I am having an issue. I currently have 48 variables named this way:
var1 = AB-101
var2 = AB-102
var3 = AB-103
var4 = AB-104
etc.
What I want to do is to use them in a while loop to create single line text, like you can see below:
  (setq iteration 1)
  (setq YValue -27.75)
     (while (<= iteration 16)
        (command "_text" "J" "M" (strcat "-53.5," (rtos YValue)) "4" "0" var1 "")
        (setq YValue (+ YValue -30.5))
     (setq iteration (1+ iteration)))
The thing is, with that loop, for each iteration, the given value is AB-101. I would like to have, for each iteration, the value of the next variable.
So, the first loop should use the variable var 1 and give: AB-101
The second loop should use the variable var 2 and give: AB-102
The third loop should use the variable var 3 and give: AB-103
And so on.
Any ideas?
Thanks a lot
Replies (7)
Message 2 of 8
Ranjit_Singh
Try replacing
with
(command "_text" "J" "M" (strcat "-53.5," (rtos yvalue)) "4" "0" (eval (read (strcat "var" (itoa iteration)))))
It will be beneficial if you posted the entire code. Is this the same problem as presented here? If so, I think the approach is unnecessarily complicated. Unless there is a specific need to copy all values to variables, you can simply read values from table and create text. Don't need variables.
Message 3 of 8
john.uhden
I pretty uch agree with @Ranjit_Singh.  Your while loop continually references specifically var1.
I suggest that rather than create a bundle of variables that you use a list of values, as in...
(setq vars (list "AB-101" "AB-102" "AB-103" etc.))
Then...
(foreach var vars
(command "_text" "J" "M" (strcat "-53.5," (rtos YValue)) "4" "0" var "")
 Do you really want separate text entities?  You could entmake or vla-add  one (1) Mtext entity instead and not need to keep adjusting YValue.
John F. Uhden
Message 4 of 8
Hi Ranjit,
When i do the replacement, it doesn't work. It says (above the command tab):
Specify other corner point or [Area/Dimensions/Rotation]: -50,-496.25
Command: _text
Current text style: "Standard" Text height: 4.0000 Annotative: No
Specify start point of text or [Justify/Style]: J Enter an option
[Align/Fit/Center/Middle/Right/TL/TC/TR/ML/MC/MR/BL/BC/BR]: M
Specify middle point of text: ; error: bad argument type: numberp: nil
Yes, It is related with my other post. The entire code makes 136 lines right now and keeps growing, so I don't think it could be beneficial to post it here. I think it may bring more confusion than clarification.
And ok now I follow you. You are saying there is an easy way to put the values of the cells 1 to 16 in the command line instead of var1, var2, var3, etc.?
If so, that could help me.
Message 5 of 8
Hi John,
The thing is, my table has three columns and sixteen lines, for a total of 48 values. The way it is meant to be used, my code needs to adapt to the quantity of values the user enter. He/she could simply enter 12 values (4 per column) for example. Lets say, for this situation, the user enters 48 values.
Then, I need to create a loop that write the text contained in the first column (16 values) to a specific place with a constant distance interval (30.5).
Then, I need to do this again with the second and third column.
Is the way I mean to use my code clearer now?
Message 6 of 8
Ranjit_Singh
Here is a sample code with 3 var values I setup and so it only iterates 3 times. As you can see it works. Compare to your existing code and identify what is different.
(defun c:somefunc  (/ iteration yvalue)
  (setq iteration 1)
  (setq yvalue -27.75)
  (while (<= iteration 3)
    (setq yvalue (+ yvalue -30.5)
  (princ))
sample_var_values.gifYou will need to share the entire code and the final goal to identify the best approach. If the code is too big then attach the .LSP file and don't paste the code.
Message 7 of 8
john.uhden
Yes, that is clearer.  My old 2002 does not allow for columns in Mtext, but newer versions do.  You seem to like plain text anyway.
I still recommend a list of values.
Lets say that the list (vars) has 22 items, and you want it divided into 3 columns.
(setq rows (/ (length vars) 3.0))  ; which results in 7.33 rows, which is > 7 by 1/3,
so the 1st column will be 8 rows, and the remaining columns will be 7 rows each.
That will guide you to the X,Y position for each piece of text.
So, you can see that the value of the list is that it not only contains all your text strings, but it has a length that can be used to determine the row count.
John F. Uhden
Message 8 of 8
I tried Ranjit's code and it works just fine in my program!
Thanks a lot to both of you guys, you are awesome!
Keep up the good work 🙂
