How to extract text values from an AutoCAD table to a drawing
Message 1 of 32
I am looking to extract text values from an AutoCAD table with an AutoLISP routine and then use those values to create a textbox.
For example, I want to use cell B3 containing the value ''Test'' and then create a textbox in AutoCAD containing the value ''Test'' (and repeat those steps with all different cell values).
How can I do that?
Replies (31)
Message 2 of 32
pbejse
How can I do that?
What is it? Can you define textbox for us stagiaireF9RWW.
Message 3 of 32
By textbox I mean the equivalent of going under the home ribbon, under annotation and clicking on Multiline Text, then selecting both corners of the textbox and entering "Test" as a value.
In Autolisp, the equivalent command is :
(command "_text" "J" "M" "0,0" "4" "0" "Test"  "")
To further clarify what I mean, I prepared an example.
Using an AutoLISP routine, I want to be able to extract values in my table (lets say 3 and Wed) and put the extracted data in a textbox, as shown to the right of my image.
I hope what I mean to do and what I meant by textbox is clearer now.
Message 4 of 32
pbejse
Okay, but is there a limit to the number of cells selected at one time?
Message 5 of 32
For the use I intend to do, I don't need to select more than one box at a time.
The way I thought the program could be written is:
(setq ValueInCellA1 CellA1)               ;gives to a variable the value contained in a cell
(setq ValueInCellA2 CellA2)
(setq ValueInCellA3 CellA3)
(setq ValueInCellB1 CellB1)
(setq ValueInCellB2 CellB2)
(setq ValueInCellB3 CellB3)
(setq ValueInCellC1 CellC1)
(setq ValueInCellC2 CellC2)
(setq ValueInCellC3 CellC3)
And then simply use those variables to create a single line text.
So maybe the simplest way to put it is this way:
How can I give to a variable the value contained in a cell?
Message 6 of 32
pbejse
Try this
(Defun c:demo  (/ xxx yyy outRow outCol )
(setq string "")
      (while
            (and (setq xxx (entsel))
                 (vla-HitTest
                       (Setq yyy (vlax-ename->vla-object
                                       (car xxx)))
                       (vlax-3d-point (cadr xxx))
                       (vlax-3d-point
                             (trans (getvar 'ViewDir) 1 0))
                       'outRow
                       'outCol
                 (setq value (vl-princ-to-string (vlax-invoke  yyy
                                        'getcellvalue  outRow  outCol)))
            	(print value)
                 (setq string (strcat string value " "))
      string
HTH
 Side note: Strangest thing, the entsel function evaluates to nil when selecting an Arial font but behaves normally with RomanS.
@Anonymous
If selecting the text evaluates to nil. try selecting the Left Vertical border of the cell adjacent to the TEXT
EDIT: DEMO CODE modified to concatenate strings
Message 7 of 32
I am not sure how to use your program. I have loaded the program in AutoLISP.
When I enter "demo" in the command bar, its says: "Select Object :"
Unfortunately, i am not able to select anything in my table. When I click on the text or the outline of the table, the program just stops. and Select object: "" appears in the command bar.
Message 8 of 32
pbejse
As I've said in my previous post, because of the odd behavior,  Your table font style probably fall into the  category I called "strange"
....If selecting the text evaluates to nil. try selecting the Left Vertical border of the cell adjacent to the TEXT ...
I attached a short video of what I meant by the above statement, (for some reason, the screencast video is stuck in "pending" status)
Notice if I select the vertical border slightly to the right, the value would be the one on the right side of the cell, if slightly left then the value at the left.
I found a code from LM and another form FIXO, if the previous code and the workaround won't cut-it for you, I will post another code based on window selection.
Message 9 of 32
I see now what the routine does and it's pretty nice! Unfortunately, it is not exactly what I am looking for. Maybe I wasn't precise enough. I'll try again.
I am looking for a code, without any interaction with the user, that takes each cells of a selected table and gives its value to a variable.
The way I want to use it : I write demo in the command bar, then I select a table.
Next, for all the data in the table (in our case, for the nine inputs, which are a,b,c,1,2,3,Mon,Tue,Wed) I want nine variables which have the different inputs as value.
For example:
Var1=a
Var2=b
Var3=c
Var4=1
Var5=2
Var6=3
Var7=Mon
Var8=Tue
Var9=Wed
Message 10 of 32
pbejse
that is actually easier than the one had in mind..
Message 11 of 32
Ranjit_Singh
Theree maybe more than one way of doing just that. Below is one example
;:Ranjit Singh
;;8/3/17
(defun c:somefunc (/ c ctr dat etdata ind lst prefix r tab tblent tblobj val varname) (setq etdata (entget (setq tblent (car (entsel "\nSelect table object: ")))) ind (cdr (assoc 91 etdata)) tab (cdr (assoc 92 etdata)) r 0 c 0 ctr 1 prefix "var" tblobj (vlax-ename->vla-object tblent)) (while (< c tab) (while (< r ind) (set (setq varname (read (strcat prefix (itoa ctr)))) (setq val (vlax-invoke tblobj 'getcellvalue r c))) (setq lst (cons (setq dat (cons varname val)) lst)) (setq ctr (if (listp (cdr dat)) ctr (1+ ctr)) r (1+ r))) (setq r 0 c (1+ c))) (vl-remove-if '(lambda (x) (listp (cdr x))) (reverse lst)))
Message 12 of 32
Ok great! In fact that is what I wanted to do! Thank you.
The only thing: I can't select the table as you did in the video. When my cursor goes over the table, it doesn't change, just as if I moved it on any empty space in my drawing. is there a way to fix that? Maybe it's a setting  that needs to be changed?
Message 13 of 32
Ranjit_Singh
stagiaireF9RWW wrote:...........................
The only thing: I can't select the table as you did in the video. ..................
I hope you have not just drawn some linework (lines/polylines etc.) to create a table? If that is an AutoCAD table entity you should be able to select it. Maybe post your drawing or a screencast.
Message 14 of 32
No of course not! Look at the images below for my situation:
1st section: Proof that it is a table
2nd section: What happens when I try to select the table
3rd section: Error message that I get
Message 15 of 32
Ranjit_Singh
Try after adding this
(vl-load-com)
at start of the routine.
Message 16 of 32
pbejse
I'm away from any computer now i , would suggest using an association list instead of multiple variables, i'll post a code as soon as i can get my hands on cad.
cheers
Message 17 of 32
Yes it works! thanks a lot Ranjit!
And pbejse, would there be any difference in the way I could use those variables with your technique?
Thanks to both of you, you are great!
Message 18 of 32
While using the routine, I have noticed that the variables' values are not exactly the way I want them to be.
How I use it:
* I copy a table in Excel
* I do a Paste Special AutoCAD Entities in AutoCAD
* I run the program
It works great with variables containing numbers. For example:
Command: !var12
112.0
For variables containing text, it doesn't work well. When I write in the command bar !var39, this is what AutoCAD gives me:
Command: !var40
"{\\fArial|b0|i0|c0;\\C7;Test"
I want the variable to be only "Test"
Is there a way to correct that?
Thank you
Message 19 of 32
Ranjit_Singh
@Anonymous wrote:
Command: !var40
That's the formatting from your excel document. Try below.
;:Ranjit Singh
;;8/3/17
       r      0
       c      0
       ctr    1
       prefix "var"
 (while (< c tab)
  (while (< r ind)
        (progn (setq val (vlax-invoke tblobj 'getcellvalue r c)
                     val (if (= 'str (type val))
                          (substr val (- (1+ (strlen val)) (vl-position (ascii ";") (reverse (vl-string->list val)))))
                          val))))
              ctr
              (1+ ctr))
         r   (1+ r)))
  (setq r 0
        c (1+ c)))
Message 20 of 32
pbejse
@Anonymous wrote:
... And pbejse, would there be any difference in the way I could use those variables with your technique?
Looking closely at Ranjit's code and GIF [ only this morning I was able to see those ]. The result is an associated list. It follows your requirement of setting a value to a variable name.
The difference with what I had in mind is lose the variable name altogether and group the values by row number.
So basically it's same same but different :), the question now is how or in what way are you planning to use those data.
