Increase number inside block
andreas7ZYXQ
andreas7ZYXQ
Im trying to develop a code that will cout increase a number inside a block/attribute.
I want to start to choose a prefix before my number. Ex. 01.xxx
Then i want to write wich number to start with after my prefix Ex. 01.001
Its important that the number have 3 digits.
After i would like to select my block, next block and so on and increase my number automatic.
Does anyone have an idea to help me. There is som issues with the code that i cant figure out on my own.
(defun C:adress()
(princ "\n ADRESS - Count the adress")
(setq textb (getstring T "\nText before nr: "))
(setq num (getint "\nStarting number: "))
(while (<= doing 50)
 (setq txt (strcat textb (itoa num) textb))
 (princ txt)
 (setq blk1 (car (entsel "\nChoose block:")))
    (setq ed (entget blk1))
	(if (= "ATTRIB" (cdr (assoc 0 ed)))
		(if (= blk1 (cdr (assoc 330 ed)))
			(if (= "ADR" (cdr (assoc 2 ed)))
				(entmod (subst (cons 1 txt)(assoc 1 ed)ed))
pbejse
Need help with your code? or are you okay with a new one?
use nentselp in selecting the ATTRIBUTE on the block
(setq blk1 (car (nentsel "\nChoose Attribute")))
(if (and (= "ATTRIB" (cdr (assoc 0 ed)))
     (= "ADR" (cdr (assoc 2 ed))))
                             (assoc 1 ed)
                             ed))
Quick edit on your code
(defun C:adress  ()
                              (nth (strlen (setq sn (itoa num)))
                                   '(nil "00" "0" ""))
                              sn))
            (princ txt)
            (IF (setq blk1 (car (nentsel "\nChoose block:")))
                  (progn
                                    (cdr (assoc 0 ed)))
                                             (assoc 1 ed)
                                             ed))
(setq num (1+ num))
andreas7ZYXQ
Thanks alot.
In my drawing i have a bunch och blocks with empty attributes. Thats why i was thinking about selecting the block since i know my attribute is always named adr.
Tried the modified code but it will not change the attribute inside the block.. Any ideas?
thanks again
pbejse
@andreas7ZYXQ wrote:
Thanks alot.
thanks again
You need to choose the ATTRIBUTE not just any part of the block, that is the way your code is setup.
Oops, you did say blank.. hang on. Will modify the code...
(defun C:adress  ()
            (setq txt (strcat textb "."
                                   '(nil "00" "0" "")) sn))
            (princ txt)
            (IF (setq blk1 (car (entsel "\nChoose block:")))
                  (progn
                        (while (/= "SEQEND"
                                (cdr (assoc 0
                                            (setq etdata
                                                       (entget
                                                             (setq blk1 (entnext blk1)))))))
                           (and (= (cdr (assoc 0 etdata)) "ATTRIB")
                                (equal (cdr (assoc 2 etdata)) "ADR")
                                               (assoc 1 etdata)
                                               etdata))))
			(setq num (1+ num))
andreas7ZYXQ
Thanks!
You just saved my day.
pbejse
No problem, You did most of the work andreas7ZYXQ.
Cheers
pBe
i think i need the same thing, but i don't really know what did you do. Can you please show me example of that block?
