AutoLISP Startup Routine Debugging Help Request
Message 1 of 12
I am setting up machines in my office with an ACADDOC.LSP AutoLISP Routine to load custom LISP routines to do the following on startup:
  1.  Initialize the drawing environment routine:
(command ".setvar" "expert" 1)
(command ".viewres" "y" "5000")
 (command ".color" "BYLAYER")
 (command ".linetype" "set" "BYLAYER")
2.Redefine the Qsave command in “Stealth Mode” to automatically purge all blocks from the drawing every drawing session:
(command ".undefine" "QSAVE")
(defun c:qsave ()
 (setvar "cmdecho" 0)
 (command "-purge" "b" "*" "n")
  (command ".qsave")
  (setvar "cmdecho" 1)
  (princ)
3.Undefine Qleader command with dialog box message to user to “Use Mleader Command!” to enforce CAD standards:
(command ".undefine" "QLEADER")
(defun C:QLEADER ()
  (command ".qleader")
  (alert "Use Mleader Command!")
   (princ)
The problem is the custom LISP routines fail to load due code errors I can’t seem to figure out!
I get the following history message after startup:
Opening an AutoCAD 2007/LT 2007 format file.
Regenerating model.
.setvar expert 1 .viewres y 5000 .-color BYLAYER ; error: misplaced dot on input
AutoCAD menu utilities loaded..setvar expert 1 .viewres y 5000 .color BYLAYER .linetype set BYLAYER .undefine
Invalid option keyword.
; error: Function cancelled
*Cancel*
*Cancel*
I am new to writing AutoLISP routines. Can anyone please help me debug the above code?
I have attached .LISP files.
All help is greatly appreciated!
Corey Barge
Replies (11)
Message 2 of 12
pbejse
Not sure, but i think you're missing a "" at  (command ".linetype" "set" "BYLAYER" "")
Try setvar instead
(setvar 'CECOLOR "BYLAYER")
(setvar 'CELTYPE "BYLAYER")
Message 3 of 12
Ranjit_Singh
Any command calls cannot be made reliably from acaddoc.lsp unless you use defun-q to define a startup function. As a result you get the error for undefine command. Also it's a good practice to add any AutoCAD environment settings to acad.lsp since you don't need to call the environment settings for every document. Typically acaddoc.lsp makes load calls only and not defines custom functions. If you start defining custom functions in acaddoc then your file we grow tremendously and maybe difficult to manage at some point.
I will add the following in acad.lsp
(setvar 'expert 1)
(setvar 'cecolor "bylayer")
(setvar 'celtype "bylayer")
The acaddoc should now call your lsp file (load "mylisps.lsp") which defines any custom functions. Make sure the mylisps.lsp file is added to a trusted location path. Or alternatively add the file location path to your trusted locations. I made mylisps.lsp with following
(command "._undefine" "QSAVE") (command "._undefine" "QLEADER") (defun c:qsave () (setvar "cmdecho" 0) (command "-purge" "b" "*" "n") (command "._qsave") (setvar "cmdecho" 1) (princ) ) (defun C:QLEADER () (command "._qleader") (alert "Use Mleader Command!") (princ) )
 Now when you open your AutoCAD application, acad.lsp will set all your environment settings and anytime you open a dwg file acaddoc will make your custom functions available in that document.acaddoc.gif
Message 4 of 12
pbejse
@Ranjit_Singh wrote:
Any command calls cannot be made reliably from acaddoc.lsp unless you .....
......will set all your environment settings and anytime you open a dwg file acaddoc will make
Wow, Wish I posted a reply as thorough as you did. 🙂
BTW: What program do you use to generate the attached GIF ? That file format is just right to show what one meant without going through a lengthy discussion, normally i posts a video from Autodesk screencast.
Message 5 of 12
Ranjit_Singh
There are many free utilities out there. Just google "screen recording". We decided to invest a little in https://www.flashbackrecorder.com/fbhome/ since we have offshore offices and its a lot faster to explain them with screen recordings. Personal choice as well (I am a man of few words Smiley Wink)
Message 6 of 12
pbejse
.... We decided to invest a little in https://www.flashbackrecorder.com/fbhome/ since we have offshore offices and its a lot faster to explain them with screen recordings. ...
Thank you, I will look into this.
Cheers
pBe
Message 7 of 12
Ranjit.Singh,
Thanks!!! It Works Great just as I wanted!Smiley Very Happy
Coreymbarge
Message 8 of 12
Ranjit_Singh
HTH. You will also find this AutoCAD Knowledgebase article very helpful.
Message 9 of 12
How do you add the file location path to your trusted locations? Smiley Embarassed
Coreymbarge
Message 10 of 12
Ranjit_Singh
You can set it in your options dialog box. Type OPTIONS
Message 11 of 12
Never mind. I found it in the "Options" "files tab.Smiley Happy
Coreymbarge
Message 12 of 12
Thanks for all the screen shots! They Really help!Smiley Wink
