Include new att block into lsp
5 REPLIES 5
miriam_ortega
387 Views, 5 Replies
I have a lsp that automatically populates my drawing tabs with the information from the TB
Currently only 1 attributed block is used but I want to add a second one
the first att is called "00000-P01"
The second one I want to include is called "DRAWING"
Both of these att blocks are within the block names "TitleBlock"
I have tried a number of combinations but nothing seems to work
Labels (2)
5 REPLIES 5
Moshe-A
in reply to: miriam_ortega
@miriam_ortega  hi,
Attached renameLOA.lsp fixed but untested cause you did not post a sample drawing
enjoy
Moshe
miriam_ortega
in reply to: Moshe-A
Thank you so much 😊
The lsp you sent works after I edited DRAWINGS for DRAWING
But one last thing, is there a way to get the separating symbol to be underscore? so it shows up as 2600_P02_Site Survey
I've attached the dwg this time
Moshe-A
fixed.
miriam_ortega
Amazing, thank you
The sample was updated in the original source of this utility - www.cadforum.cz/freeware
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
AutoCAD Inside the Factory
