Importing DIMSTYLE; setting as ACTIVE DIMSTYLE; and preserving current DIMSCALE
Hi all, I'm having issues with this LISP in ACAD 2014. I'm unsure why, but the intent is to import a dimstyle via a block depending on the MEASUREMENT variable for Metric and Imperial styles.
What I'm running into is each time the command runs, it brings in the dimstyle, but it resets the DIMSCALE to 1 and does not set it as the current dimstyle. Any help is appreciated. Thanks!
(defun c:dim_lin (/ ds dskbk dim acdoc)
(setq	ds	(if (= (getvar 'measurement) 0)
			"s2014"
			"s2014 - M"
(setq	dsbk	(strcat "*" @dwg "dim_" ds ".dwg") 		;define dimstyle block
	dim	(getvar 'dimscale)				;gets dimscale for cmleaderscale
(if 	(tblsearch "dimstyle" ds);test
	(progn						;thenexprs
	(setq	acdoc	(vla-get-activedocument (vlax-get-acad-object)))
	(vla-put-activedimstyle acdoc (vla-item (vla-get-Dimstyles acdoc) ds))
	);endthen
	(progn						;elseexprs
	(command "-insert" dsbk "0,0" "1" "1" "0")	;place dsbk
	);endelse
);endif
(initcommandversion)
(command ".dimlinear")				;run command
(while 	(> (getvar 'cmdactive) 0)
	(command pause)
	);endwhile
);enddefun
hmsilva
Hi cgentile,
when set as current a different dimstyle, all overrides values will be discarded...
And hoping '@dwg' be a gloval variable... perhaps something like this...
             "s2014"
             "s2014 - M"
  (if (tblsearch "dimstyle" ds) ;test
    (progn ;thenexprs
      (setvar 'dimscale dim)
    )     ;endthen
    (progn ;elseexprs
      (command "-insert" dsbk "0,0" 1 1) ;place dsbk
      (command) ; cancel the insert
    )     ;endelse
  )       ;endif
    (command pause)
  )       ;endwhile
  (princ)
)         ;enddefun
Hope this helps,
Henrique
