Message 1 of 12
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
I'm trying to import a profile (.arg) through lisp. We will be doing a silent deployment of the acaddoc.lsp to +50 computers. Ive seen several lisps that claim to do this but since I'm not the best coder my understanding is limited. For example: from JTB world(I keep seeing this as a solution to quite a few forums). I don't know where I would actually put the profile location or name. Code below. Thank you in advance!
;;; profiles.lsp
;;; miscellaneous profile commands
;;; By Jimmy Bergmark
;;; Copyright (C) 1997-2008 JTB World, All Rights Reserved
;;; Website: www.jtbworld.com
;;; E-mail: info@jtbworld.com
;;; 2000-01-25
;;; 2003-01-23 Added functions
;;; 2008-08-08 Added forceImport
(vl-load-com)
; Brute force a profile to be imported
; (forceImport "profilename" "C:\\temp\\testprof.arg" 1)
; inclpathinfo=1 The path information in the registry file will be preserved.
; inclpathinfo=0 The path information in the registry file will not be preserved.
; return T if profile is imported
(defun forceImport (profilename argname inclpathinfo / tmp1 tmp2)
(setq tmp1 "<<most-temporary1>>")
(deleteProfile tmp1)
(if (importProfile tmp1 argname inclpathinfo)
(progn
(putActiveProfile tmp1)
(deleteProfile profilename)
(renameProfile tmp1 profilename)
(putActiveProfile profilename)
T
nil
(defun getActiveProfile ()
(vla-get-activeprofile
(vla-get-profiles (vla-get-preferences (vlax-get-acad-object)))
(defun putActiveProfile (profilename)
(vla-put-activeprofile
profilename
(defun getAllProfileNames(/ allprofiles)
(vla-getallprofilenames
'allprofiles
(vlax-safearray->list allprofiles)
(defun existProfile (profilename)
(not (not (member
(strcase profilename)
(mapcar '(lambda (x) (strcase x)) (getallprofilenames))
(defun c:listProfileNames(/ nr profnames)
(setq nr 0)
(setq profnames (getAllProfileNames))
(repeat (length profnames)
(princ (nth nr profnames))
(print)
(setq nr (1+ nr))
(princ)
; return T if profile is deleted and nil if not
(defun deleteProfile (profilename)
(if (and
(/= (strcase profilename) (strcase (getActiveProfile)))
(existProfile profilename))
(not (vla-deleteprofile
profilename
; Delete all profiles except the current profile
(defun deleteAllProfilesExceptCurrent (/ item)
(foreach item (getAllProfileNames)
(vl-catch-all-apply
'vla-deleteprofile
(list (vla-get-profiles
item
; return T if profile is reseted and nil if not
(defun resetProfile (profilename)
(if (existProfile profilename)
(not (vla-resetprofile
profilename
; return T if profile is renamed and nil if not
; if profilenameNew exist it's substituded with profilenameOld
(defun renameProfile (profilenameOld profilenameNew)
(if (existProfile profilenameOld)
(not (vla-renameprofile
profilenameOld
profilenameNew
; return T if profile is copied and nil if not
; if profilename2 exists it's copied
(defun copyProfile (profilename1 profilename2)
(if (existProfile profilename1)
(not (vla-copyprofile
profilename1
profilename2
; (exportProfile "profilename" "C:\\TEMP\\profilename.arg")
; if path is omitted profile is saved in active directory
; overwrites argname if it exists
; return T if profile is exported
(defun exportProfile (profilename argname)
(not (vla-exportprofile
profilename
argname
; (importProfile "profilename" "C:\\TEMP\\profilename.arg" 1)
; overwrites profilename if it exists
; if path is omitted profile is imported from active directory
(defun importProfile (profilename argname inclpathinfo)
(not (vl-catch-all-apply 'vla-importprofile (list
profilename
argname
inclpathinfo
; Brute force a profile to be imported and all the resting to be deleted
; (forceImportAndDeleteTheRest "profilename" "C:\\temp\\testprof.arg" 1)
(defun forceImportAndDeleteTheRest (profilename argname inclpathinfo / tmp1 tmp2)
(progn
(deleteAllProfilesExceptCurrent)
T
nil
