Images Toggle
Images Toggle
richie_hodgson
Images Toggle
richie_hodgson
Ok it all seemed so easy, but I seem to be getting nowhere. I would like a lisp to toggle all images in the drawing between loaded or unloaded
I tried
(vl-load-com)
(defun c:IMT (/ i lst obj ss)
  (setq lst "")
  (prompt "\nSelecting All Images to Unload: ")
  (if (setq ss (ssget "x" (list (cons 0 "IMAGE"))))
    (progn
      (repeat (setq i (sslength ss))
        (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i))))
              lst (strcat lst "," (vla-get-name obj))
      (vl-cmdf "-Image" "_U" lst)
  (princ)
Just to unload all of them, but it worked once then not again. Has anyone got a working piece of code to toggle between reload and unload, or something that will unload and reload seperately
Richie
Accepted solutions (3)
paullimapa
Should be no special function needed:
To Unload All Images at command prompt type:
-Image
U
To Reload All Images at command prompt type:
-Image
R
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Paul Li
IT Specialist
@The Office
richie_hodgson
That gave me another idea, cool.
Richie
braudpat
Hello
For this purpose :
Unload / Reload ALL Images
Unload / Reload ALL Xrefs
I use a nice routine from Gilles (gile)
I0 : ALL Images OFF
I1 : ALL Images ON
X0 : ALL XREFs OFF
X1 : ALL XREFs ON
Thanks to Gilles (a french Expert Developer)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
richie_hodgson
Hi there
That looks very interesting, will test it later today.  Thank you in advance.
Richie
Richie
richie_hodgson
Very cool, will have to check how the image part works as I am not sure about that bit of the code.
Richie
