IMAGEATTACH use in script files (Suppress Dialog box showing)
I am using a script file to attach many images into multiple AutoCAD drawings. Each line in the script file looks like this:
_imageattach "C:\Images\test.jpg" 5.0,-2.xxx-xxxxxxxx 5.0
where the 5.0,-2.xxx-xxxxxxxx is the bottom left coordinate and the 5.0 is the scaling.
Although this works fine, a dialog box pops up for every image. For each dialog box I have to click 'ok' before the image attaches. Is there any way to avoid the dialog box popping up?
Tom
ВeekeeCZ
-IMAGE command?
pendean
Community Legend
Community Legend
i did this unintetionaly and foud the solution to get my popup dialog box back,
enter comand:
SYSVARMONITOR
cange FILEDIA from 1 to 0
and all popups are blocked:
FILEDIA (System Variable)
Suppresses display of file navigation dialog boxes.
Type:Integer
Saved in:Registry
Initial value:1
Value
Description
0
Does not display dialog boxes. You can still request a file dialog box to appear by entering a tilde (~) in response to the Command prompt.
1
Displays dialog boxes. However, if a script is active, an ordinary prompt is displayed.
Prompts are also displayed if an AutoLISP or ObjectARX™ program is active. (Not applicable to AutoCAD LT.)
