IMAGE ADJUST LISP?
IMAGE ADJUST LISP?
rob.aHH2T8
IMAGE ADJUST LISP?
rob.aHH2T8
Does anyone have a LISP for adjusting an image with Properties-Image Adjust?  (brightness/ contrast/ fade)acad image adjust.JPG
rkmcswain
Should be pretty trivial
Have you started writing something or just looking for something existing?
ВeekeeCZ
Now I do. The values offered by prompts are from the first img of selection. So if you want to match values of one to many, select the one by a single click, then the rest.
(defun c:ImageAdj ( / s o b c f i e)
  (if (and (setq s (ssget "_:L" '((0 . "IMAGE"))))
	   (setq b (cond ((getint (strcat "\nBrightness <" (itoa (setq o (getpropertyvalue (ssname s 0) "Brightness"))) ">: "))) (o)))
	   (setq c (cond ((getint (strcat "\nContrast <" (itoa (setq o (getpropertyvalue (ssname s 0) "Contrast"))) ">: "))) (o)))
	   (setq f (cond ((getint (strcat "\nFade <" (itoa (setq o (getpropertyvalue (ssname s 0) "Fade"))) ">: "))) (o)))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i))))
      (setpropertyvalue e "Brightness" b)
      (setpropertyvalue e "Contrast" c)
      (setpropertyvalue e "Fade" f)))
  (princ)
rob.aHH2T8
Looking for a solution, so I don't have to adjust it manually every time.
rob.aHH2T8
Thanks!  Where do I put in the values?  (b=30, c=70, f=50)
ВeekeeCZ
Hardcoded:
	   (setq b 30)
	   (setq c 70)
	   (setq f 50)
  (princ)
Sea-Haven
As its hard coded why have b c f.
(defun c:ImageAdj ( / s i e)
  (if (setq s (ssget "_:L" '((0 . "IMAGE"))))
      (setpropertyvalue e "Brightness" 30)
      (setpropertyvalue e "Contrast" 50)
      (setpropertyvalue e "Fade" 70))
  (princ)
