If - Then based on the color of a specific layer
jpCADconsulting
jpCADconsulting
Hiya folks, long time no Code. I have need for an if/then operation based on the color of a specific layer (in my case L-ANNO-SYMB). So... this will be some code in acaddoc.lsp On fileopen I want AutoCAD to check for the color of layer L-ANNO-SYMB in the current file If it's 150, it will import page setups from one file Else it will load page setups from a different file I have the code for importing page setups form a file and it work fine, I just need the if/them bit and I'm not quite sure how to do it. Thanks as always!
BlackBox_
(if
  (and
    (setq var (tblsearch "layer" "L-ANNO-SYMB"))
    (setq var (cdr (assoc 62 var)))
   (if (= 150 var)
     ;; import from one
     ;; import from the other
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
Kent1Cooper
More concisely:
(if (member '(62 . 150) (tblsearch "layer" "L-ANNO-SYMB"))
  (then -- load from one file)
  (else -- load from other file)
The (if) test will return nil if either the Layer's color is not 150 or the Layer does not exist, all in one, and without involving a variable.
Kent Cooper, AIA
ВeekeeCZ
@BlackBox_ wrote:
(if
  (and
   (if (= 150 (abs var))
     ;; import from one
In case it's off.
BlackBox_
@Kent1Cooper wrote:
More concisely:
Excellent point @Kent1Cooper, I feel like my .NET is creeping into my LISP these days. Haha
Cheers
BlackBox_
@ВeekeeCZ wrote:
@BlackBox_ wrote:
(if
  (and
     ;; import from one
In case it's off.
Thanks, @ВeekeeCZ !
Kent1Cooper
In case it's off.
Good point.  It can still be done without a variable:
(if (member (cdr (assoc 62 (tblsearch "layer" "L-ANNO-SYMB"))) '(150 -150))
Kent Cooper, AIA
