IF I SELECT THE LINE HOW TO GET THE START AND END POINT OF TEXT ?
jaimuthu
jaimuthu
I draw the traingle  A B D if i select the line how i get the start and end point of text ?Traingle.jpg
Kent1Cooper
If you mean how to you get the Text objects near the start and end points of the Line, a question:
Is the triangle made of LINE entities specifically, or is it a POLYLINE?  The answer makes a big difference in the way of determining where those endpoints are.
Then it would probably need to use (ssget) with a window built around the endpoints, at some size that is sure to include the Text within it.
Kent Cooper, AIA
jaimuthu
Yes ,This is a line entities
devitg
@jaimuthu , for better understanding, please upload your sample.dwg
Sea-Haven
So select line you want the "B" & "D" or the "Leader" text pointing to the end points, clarify in your dwg that needs to be posted.
jaimuthu
Select the Line i want B & D (Text Value) for (alert messagebox in lisp )
