if else statement inside cond
DGRL
Advisor Advisor
DGRL
Dear forum members,
I have a small routine with dcl to plot some dwg
Now I need an if else statement as overlay of an cond
If in my dcl menu button x is selected take over all the settings and do something
If the same button is not selected do something else
Here is my code ( below is more text to explain!!)
(if(= ddiag 2)
     (progn
   ;(princ "\n Using Radio_column data...You chose ")
 (cond
  ((= Choice3 "12")
 (progn
  (c:my_plot)
 );end progn
 ) ; end choise
  ((= Printer "1")
 (progn
 (princ "You selected the System printer")
 (if (= choice1 "7")(c:A3))
 (if (= choice1 "8")(c:A4L))
 (if (= choice1 "9")(c:A4P))
 (if (= choice2 "10")(c:Pr-A3L))
 (if (= choice2 "11")(c:Pr-A4L))
 (setvar "cmdecho" oldcmdecho)
 );end progn
 ) ; end Printer1
  ((= Printer "2")
 (progn
 (princ "You selected the DWG To PDF printer")
 (if (= choice "4")(c:PDFA0))
 (if (= choice "5")(c:PDFA1))
 (if (= choice "6")(c:PDFA2))
 (if (= choice1 "7")(c:PDFA3))
 (if (= choice1 "8")(c:PDFA4L))
 (if (= choice1 "9")(c:PDFA4P))
 (if (= choice2 "10")(c:PDF-A3L))
 (if (= choice2 "11")(c:PDF-A4L))
 );end progn
 ) ; end Printer2
  ((= Printer "3")
 (progn
 (princ "Are you sure you wanna have TIF?")
 ;(command "script" scr ) nice way to make temp scr files to execute LOL
 ;(alert "Still to be implemented")
 (command "script" "AlgemeenTIFF.SCR")
 );end progn
 ) ; end printer3
 ) ;end cond
 ) ;end progn
 ) ;end if ddiag
What I want is that when Choice3 is selected It needs to skip Printer 1 / 2 and 3
When Choice3 is not selected is needs to do Printer 1 / 2 and 3 and skip Choice3
I hope I am not to confusing with this
Code can be changed in any way as long as it will work lol
I broke my head on this one so far
Kind regards,
If this was of any help please kudo and/or Accept as Solution
Kind Regards
ВeekeeCZ
Not sure if i do follow you, but it seems that you need to use the IF function instead of COND.
(if (= Choice3 "12")
  (c:my_plot)
  (progn
    (if (Printer "1")
      (progn
    (if (= Printer "2")
      (progn
    (if (= Printer "3")
      (progn
If there is something like this:
... it indicates that the COND function is not good idea, because cond allows you to take JUST ONE (the first one which is T) condition.
EDIT: Not sure why you have so many variables... and unique choices... this is probably good place to use COND
  (c:my_plot)
  (progn
    (if (Printer "1")
      (progn
        (cond ((= choice1 "7") 	(c:A3))
              ((= choice1 "8")		(c:A4L))
              ((= choice1 "9")		(c:A4P))
              ((= choice2 "10")	(c:Pr-A3L))
              ((= choice2 "11")	(c:Pr-A4L))
    (if (= Printer "2")
      (progn
        (cond ((= choice "4")		(c:PDFA0))
              ((= choice "5")		(c:PDFA1))
              ((= choice "6")		(c:PDFA2))
              ((= choice1 "7")		(c:PDFA3))
              ((= choice1 "8")		(c:PDFA4L))
              ((= choice1 "9")		(c:PDFA4P))
              ((= choice2 "10")	(c:PDF-A3L))
              ((= choice2 "11")	(c:PDF-A4L))
    (if (= Printer "3")
      (progn
DGRL
Hi @ВeekeeCZ
Thanks for the reply
When I run your routine Im getting error Error: bad function: "2"
This one also works, as I just fixed It lol
(if(= ddiag 2)
     (progn
 (if button12
(c:my_plot)
 (cond
  ((= Printer "1")
 (progn
 );end progn
 ) ; end Printer1
  ((= Printer "2")
 (progn
 );end progn
 ) ; end Printer2
  ((= Printer "3")
 (progn
 );end progn
 ) ; end printer3
 ) ;end cond
 ) ;end if choice3
 ) ;end progn
 ) ;end if ddiag
This one work but im running into another problem
I will make a new topic for that one after a while ( I wanna try myself first )
Kind Regards
ВeekeeCZ
@DGRL wrote:
Hi @ВeekeeCZ
(= Printer "1")
