IF CONDITION
IF CONDITION
muhamed_ragab92
Message 1 of 27
IF CONDITION
muhamed_ragab92
I WANT TO KNOW , HOW CAN I MAKE IF CONDITION TO COMPARE BETWEEN TWO ISSUES AND SELECT THE RESULT IN TEXT ? I KNOW SOME FEATURE FOR CTRL+F BUT I CANT MAKE IF CONDITION
Replies (26)
Message 21 of 27
Scottu2
muhamed_ragab92,
I rewrote the routine to muti-select Source and Target objects.
I expected the amps and cables to be aligned vertically and paired together.
(i know for larger breaker the are no decimals but i included detection anyway - (Getnumber string)
See the attached Cables2.LSP
Let me know how it goes this time.   🙂
Message 22 of 27
muhamed_ragab92
thanks scott i tried it and modify in the routine in some breakers types and cables , it worked but have small issue i recorded it to you , the script worked fine when select by blue shadow on breakers and cables and it has issue when select on another anything else i mean i cant select by green shadow , all what i talked about will notice in recorded video and i uploaded you the modified lisp
Message 23 of 27
Scottu2
I'm glad it worked for you.
Thanks for posting the screen video. I can see that selecting by window function worked.  But selecting by crossing did not work.
I suspect there is another block selected since the selected objects increased from 13 to 26.  The routine is not specific enough to capture the breaker blocks only, and then plain text only.   I will post a revision when i can verify it with your sample drawing.
Message 24 of 27
muhamed_ragab92
yup i will wait this update , thanks
Message 25 of 27
Scottu2
muhamed_ragab92,
This should fix that issue of selecting by crossing, CABLES3.LSP
I changed the selection routine to select the AT block by tag name only and Plain text.
Message 26 of 27
muhamed_ragab92
thanks scottu2 finally it worked
Message 27 of 27
Scottu2
muhamed_ragab92,
Your welcome.  I'm glad to help you.    🙂
