IF CONDITION
IF CONDITION
muhamed_ragab92
Message 1 of 27
IF CONDITION
muhamed_ragab92
I WANT TO KNOW , HOW CAN I MAKE IF CONDITION TO COMPARE BETWEEN TWO ISSUES AND SELECT THE RESULT IN TEXT ? I KNOW SOME FEATURE FOR CTRL+F BUT I CANT MAKE IF CONDITION
Replies (26)
Message 2 of 27
Kent1Cooper
I'm not sure exactly what you mean.  Ctrl+F toggles running Object Snap on or off, and has nothing to do with (if) tests or Text.  What does it mean to "select the result in text?"  The word "select" is usually about picking already-drawn objects in the drawing.  Do you mean to draw  some Text in the drawing as the result of the (if) test?
An (if) function doesn't "compare between two issues," but performs a test, and if it returns anything other than nil, does what is called for by its 'then' expression, or if it returns nil, its 'else' expression.  But the test it performs could include two test within it, with an (and) function -- if test 1 and  test 2 both  return something other than nil can be combined into one 'test' expression.  But it's still not really "comparing" the issues, but checking each one by itself.
Of, if you mean you want the User to select between two [or more] choices or options by entering text  [typing something] to make the choice, this is how that is usually done:
(initget "Yes No")
(setq option (getkword "\nDo you want to do this [Yes/No] <N>: "))
(if (= option "Yes")
  (... do whatever it is ...); 'then' expression
  (... do something else ...); 'else' expression
); end if
The User can either type in the Y or N [upper- or lower-case] or the whole words, or in newer versions pick the option inside the prompt, and (getkword) will return the whole word.
If you include more than two options, (cond) would be a better function than (if) for doing what is wanted for the option the User choses.
Some more explanation of what the conditions are that you want to compare, and how Text fits in, would be helpful.
Kent Cooper, AIA
Message 3 of 27
muhamed_ragab92
first i'd really to thank you for your answer and i record a video to explain what i want - and ctrl+f which means when use it at text for functions
here's the link of video
Message 4 of 27
Scottu2
Kent1cooper,
Based on the video, it looks like muhamed_ragab92 needs a lisp routine that
1. Selects a source object to determine the amp rating of the circuit breaker, then
2. Selects a target object to replace the existing text with a pre-determined Cable size on the incoming line side.
If 160A use Cable 3x95
if 250A use Cable 3x150
if 1000A use Cable 3x240
Message 5 of 27
muhamed_ragab92
Yes exactly thats what i need it and can i edit in it
Message 6 of 27
roland.r71
It looks to me as if he's trying to create a conditional field (hence: CTRL+F).
So, he should be looking into DIESEL expressions.
The next example shows a different name (or default text) based on the user logged on.
However, that's as far as my own understanding of DIESEL goes, so i can't say IF and/or how to do it for the given case.
%<\AcDiesel
$(if,$(eq,$(getvar,loginname),"Jeff"),"jeff[at]cadstudio.cz",
$(if,$(eq,$(getvar,loginname),"John"),"john[at]cadstudio.cz",
$(if,$(eq,$(getvar,loginname),"Mary"),"mary[at]cadstudio.cz",
"cannot detect e-mail address")))
source: http://www.cadforum.cz/cadforum_en/conditional-text-fields-in-autocad-tip10239
Perhaps using a lisp to set the text, without using fields and stuff might be better, but i'll leave that to the experts 😛
Message 7 of 27
Scottu2
roland.r71,
I thought it was something complex using the dialog boxes and fields, but i believe it was used to express the logic concept via coding.
Message 8 of 27
Scottu2
Mahumad.ragab92,
Try this routine...
; Cables - 4/23/2018
; Scott Uyehara
;This routine will ask for two entities, source and target:
;  Source Breaker Amps
;  Target Cable Text
; scan text for numbers and stop at first letter or end of text
; generate Cabletext result based on Amp value
; substitue old value for new, DXF 1 value
(defun c:cables (/ a ed text1 b edb old c1 ltr pren1 pren2 div1 cmdech)
;  global values: txta, textcables
;-- stop the UNDO command
(setq cmdech (getvar "cmdecho"))
(setvar "cmdecho" 0)
(command "undo" "group")
(command "undo" "end")
(setvar "cmdecho" cmdech)
  ;get source & target
  (setq a (entsel "Select Breaker Amps Text <or Enter>: "))
  (if (= a nil)
    (setq text1 (strcase (getstring "\nEnter Breaker AMPS or S=Spare: ")))
    (progn
      (setq ed (entget (car a)))
      (setq text1 (cdr (assoc 1 ed)))
    );if = a nil
  (setq b (entsel "Select Cable text: "))
  (setq edb (entget (car b)))
  (setq old (assoc 1 edb))
;filter text string
;rebuild string text1 --> txta
  (setq c1 0)
  (setq txta "")
  (while (<= c1 (strlen text1))
    (setq c1  (+ c1 1))
    (setq ltr (substr text1 c1 1))
    (if (and (>= ltr "0") (<= ltr "9")) (setq txta (strcat txta ltr))); keep it when 0-9
    (if (> ltr "9") (setq c1 (+ 1 (strlen text1))))
  );while
  (prompt "\nAMPs: ")(princ txta)
  ;output No Match is nonthing matches
  (setq textcables "NO MATCH")
  (setq pren1 (chr 40))
  (setq pren2 (chr 41))
  (setq div1 (chr 47))
  (if (= txta "150") (setq textcables (strcat "CABLE" pren1 "3x95+50" pren2 "mm2,CU" div1 "XLEP" div1 "PVC")))
  (if (= txta "250") (setq textcables (strcat "CABLE" pren1 "3x150+70" pren2)))
  (if (= txta "630") (setq textcables (strcat "CABLE" pren1 "3x240+120" pren2)))
  (if (= txta "1000") (setq textcables (strcat "CABLE" pren1 "3x240+120" pren2)))
  (if (= txta "S") (setq textcables "SPARE"))
  (setq new (cons 1 textcables))
  (setq edb (subst new old edb))
  (entmod edb)
(prompt "\nUse Cables: ")
(prompt textcables)
(princ)
); defun
Message 9 of 27
muhamed_ragab92
its worked but in text only when c.b amp is text not attribute , can we add attribute to the script ?? and i will record video for what done with this routine
Message 10 of 27
muhamed_ragab92
Reminder for issue
Sent from my iPhone
Message 11 of 27
Scottu2
muhamed_ragab92,
Thanks for the reminder.
I tested the code and noticed that the Spare option was not working.
Change the variable txta to text1, (if (= txta "S") (setq textcables "SPARE"))
I will adjust the code for attribute detection.
Scott U.
Message 12 of 27
muhamed_ragab92
Okay thanks
Sent from my iPhone
Message 13 of 27
Scottu2
muhamed_ragab92,
Try this routine with attribute detection.
Its not tested (due to computer problems), but lets see how it goes.
Message 14 of 27
muhamed_ragab92
thanks you , i tried this routine today but the result when select amp c.b 250a or any others is no match at cable
Message 15 of 27
Scottu2
muhamed_ragab92,
I made corrections.  See attached files.
Also, change the attribute tag names to match your drawing.
Source block with attribute tag "amps"
Target block with attribute tag "linecables"
;predefine tag name
(setq tagname "amps")
(setq tagnameB "linecables")
Scott
Message 16 of 27
muhamed_ragab92
its worked but i modify in the routine in 250A , 630A and 1000A because type of isolation appeared only 150A - and modify tagname to AT to suitable with me , can we add the feature to the lisp which i can select many several of breakers and after that select the texts i know its more advanced in the routine but can we add it? - attached file is screenshot from the result and the modified lisp - thanks
Message 17 of 27
Scottu2
muhamed_ragab92,
Good,  modified it to work for the other amp values.
I see that tagnameB (used for cabletext) was not changed.
Is that because it is always pain text?
As for the advanced feature to select a group of AT breakers and the matting cable text,
Please post a sample drawing.  I may have more questions.
Message 18 of 27
muhamed_ragab92
yes ,  it is always pain text for me - it's not find on anywhere - i ask if we can add it to select by mouse many of breakers at once and and select after that the pain texts once - convert directly all texts to which write the routine
Message 19 of 27
Scottu2
muhamed_ragab92,
Ok.  Thanks great.  Its a little more involved.  I plan to rewrite the code.
Message 20 of 27
muhamed_ragab92
Thanks , i appreciate that
Sent from my iPhone
