i want to mark polyline curves on horizontal lines by using lisp
nilesh.bhosale
Message 1 of 9
nilesh.bhosale
I have a task to mark polyline curves horizontally by selecting the polyline it should automatically draw the horizontal
line on which all the curves shall be mark on it
SAMPLE DRAWING ATTACHED FOR UNDERSTAING
Replies (8)
Message 2 of 9
Kent1Cooper
If your indication of curve numbers within the string of dimensions is just to illustrate for us, and you don't really need them called out separately, you can use >StretchPolylinesStraight.lsp< and then just use the QDIM command on the resulting straightened-out Polyline.  It preserves the vertex locations along the result if that's desirable, unlike your example of a single Line object.
[I pulled the dimension-line location up a little on two very short ones, but otherwise QDIM handled them all.]
Would they always be strictly alternating between line and arc segments, with line segments at both ends?  If so, it might not be hard to throw something in to call out which straight Dimensions represent curves.
Kent Cooper, AIA
Message 3 of 9
Kent1Cooper
And another question:  What determines the height of the "rectangles" [only three-sided] along the portions representing the arc segments, and why is the one for Curve No-7 different in height from the rest?
Kent Cooper, AIA
Message 4 of 9
nilesh.bhosale
please refer bellow attached drawing
rectangle height can be taken in such way that it should not higher than the curve length, rectangle height is  not major concern here.
all the rectangles should be with same height
Message 5 of 9
devitg
@nilesh.bhosale
could it be so?
Message 6 of 9
nilesh.bhosale
YES Sir,
this is what i need can you share its lisp codes ??
Message 7 of 9
hak_vz
Here you have lisp code that creates horizontal polyline whose length equals to total length of the road. After you enter rectangle height (for curve segments) and pick road polyline it ask you to pick a point where you want your diagram created and it creates rectangles for curved segments at distance from road poly start point. If you need it in opposinte direction mirror the diagram. For counting curves place dummy text (let say xxx) and use express tools command TCOUNT for counting, option override with prefix let say "#-". I didn't put text creation in the code since you may have trouble working with mirrored text.
(defun c:prel (/ *error* adoc take pointlist2d pick_poly rh eo coords bulge_list dist_list i total_lenght p1 p2 cnt sum_dist old);
  (defun *error* (msg)
    (and
      msg
      (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*BREAK*,*EXIT*"))
      (princ (strcat "\nError: " msg))
    (setvar 'osmode old)
	(setvar 'cmdecho 1)
    (princ)
	(defun take (amount lst / ret)(repeat amount (setq ret (cons (car lst) (take (1- amount) (cdr lst))))))
	(defun pointlist2d (lst / ret) (while lst (setq	ret (cons (take 2 lst) ret) lst (cddr lst))) (reverse ret))
	(defun pick_poly (msg)
		(setq e (car(entsel msg)))
		(if (and (not e) (= (getvar 'Errno) 7)) (pick_poly msg) e)
	(setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
    (vla-startundomark acdoc)
	(setq rh (getreal "\nEnter rectangle height >"))
	(setq eo (vlax-ename->vla-object (pick_poly "\nSelect road curve > ")))
	(setq bulge_list nil dist_list nil)
	(setq coords (pointlist2d(vlax-get eo 'coordinates)))
	(setq total_lenght (vla-get-length eo))
	(setq i -1)
	(while (< (setq i (1+ i))(1- (length coords)))
	(setq bulge_list (cons (vla-getbulge eo i) bulge_list))
	(setq dist_list (cons (- (vlax-curve-getDistAtPoint eo (nth (1+ i) coords))(vlax-curve-getDistAtPoint eo (nth i coords))) dist_list))
	(setq dist_list (reverse dist_list) bulge_list (reverse bulge_list))
	(setq p1 (getpoint "\nSelect point >"))
	(setq p2 (polar p1 0 total_lenght))
	(entmakex
		(apply 'append
			(cons
			  (list
				'(0 . "LWPOLYLINE")
				'(100 . "AcDbEntity")
				'(100 . "AcDbPolyline")
				'(410 . "Model")
				'(38 . 0)
				'(67 . 0)
				'(70 . 0)
				(cons 90 2)
			  (mapcar 'list (mapcar '(lambda (a) (cons 10 a)) (list p1 p2)))
	(setq i -1 cnt 0 sum_dist 0.0)
	(setq old (getvar 'osmode))
	(setvar 'osmode 0)
	(setvar 'cmdecho 0)
	(while (< (setq i (1+ i)) (length bulge_list))
		(cond
			((/= (nth i bulge_list) 0.0)
				(setq cnt (1+ cnt))
				(command "_.rectang" "_none" p1 "_none" (mapcar '+ (mapcar '+ p1 (list (nth i dist_list) 0)) (list 0 rh)))
				(command "_.move" (entlast) "" "_none" p1 "_none" (polar p1 0 sum_dist))
		(setq sum_dist (+ sum_dist (nth i dist_list)))
	(setvar 'cmdecho 1)
	(vla-endundomark acdoc)
	(princ)
Miljenko Hatlak
Message 8 of 9
john.uhden
This might be easier on your processor
Presuming:
e = entity name
ent = list of entity data
blist = list of bulges
plist = list of vertex points
dlist = list of distances (from 0) of each vertex
dseglist = list of segment distances
(setq blist (mapcar 'cdr (vl-remove-if-not '(lambda (x)(= (car x) 42)) ent)))
(setq plist (mapcar 'cdr (vl-remove-if-not '(lambda (x)(= (car x) 10)) ent)))
(setq dlist (mapcar '(lambda (x)(vlax-curve-getdistatpoint e x)) plist))
(setq copy dlist dseglist nil)
(repeat (1- (length dlist)) (setq dseglist (cons (- (cadr copy)(car copy)) dseglist) copy (cdr copy)))
Of course if dseglist is localized, you don't have to set it to nil.
Just gotta take care of closed polylines.
John F. Uhden
Message 9 of 9
nilesh.bhosale
Sir thank you very much this is working perfectly fine
