I want to enhance this LISP
carminatithekid1
carminatithekid1
I am looking for someone to tell me what to place in this lisp, and where, so the command will repeat.
(defun c:d_fillet (/ dscale fill_rad pt1 pt2)
(princ "\nCUSTOM FILLET")
(setq dscale (getvar "dimscale"))
(princ " Current Dimscale is: ")(princ dscale)
(setq fill_rad 0.1)
(setq fill_rad (* dscale fill_rad))
(while (null (setq PT1 (entsel "\nSelect first line: ")))
(princ "\nNo object found")
(redraw (car PT1) 3)
(while (null (setq PT2 (entsel "\nSelect second line: ")))
(redraw (car PT2) 3)
(command "fillet" "rad" (rtos fill_rad)
"fillet" pt1 pt2)
(redraw (car PT1) 4)
(redraw (car PT2) 4)
(princ)
Randy Carminati
ВeekeeCZ
Like this?
(defun c:d_fillet (/ pt1 pt2)
  (command "_.FILLET" "_Rad" (rtos (* (getvar 'DIMSCALE) 0.1)))
  (princ "\nCurrent Dimscale: ") (princ (getvar 'DIMSCALE))
  (princ "\nCurrent Radius: ") (princ (getvar 'FILLETRAD))
  (while (setq PT1 (entsel "\nSelect first line <done>: "))
      (princ "\nNo object found"))
    (command "_.FILLET" pt1 pt2)
    (redraw (car PT2) 4))
  (princ)
While - you'll pick some first line - then you can continue the selection the other and fillet those...
Kent1Cooper
How about simply making use of the Multiple option in the Fillet command?  Much simpler, because the Fillet command itself will also take care of much of what your code does [e.g. asking again if you miss, highlighting]:
(defun c:d_fillet ()
  (princ " Current Dimscale is: ") (princ (getvar "dimscale"))
  (setvar 'filletrad (* (getvar "dimscale") 0.1))
  (command "_.fillet" "_multiple")
Kent Cooper, AIA
carminatithekid1
Can I ask to have you guys help me simplify this code as well? Very similar to the previous fillet, but I now want a chamfer tool that takes into account the current dimscale and will also keep going without having to start the command again.
(defun c:d_chamfer (/ dscale cham_dist pt1 pt2)
(setvar "cmdecho" 0)
(setq cham_dist 0.1)
(setq cham_dist (* dscale cham_dist))
(command "chamfer" "d" (rtos cham_dist) ""
"chamfer" pt1 pt2
(princ)
Randy Carminati
ВeekeeCZ
Actually it is pretty much the same. So how about take Kent's version as the pattern, look into the HELP what variables you need to set and try to rewrite it by youself. If you'll get stuck, post the code here.
Good luck!
Kent1Cooper
@Anonymous wrote:
.... I now want a chamfer tool that takes into account the current dimscale and will also keep going without having to start the command again.
That has a Multiple option, too:
(defun c:d_chamfer (/ dscale)
  (princ "\nCUSTOM CHAMFER")
  (princ " Current Dimscale is: ") (princ dscale)
  (setvar 'chamfera (* dscale 0.1))
  (setvar 'chamferb (* dscale 0.1))
  (command "_.chamfer" "_multiple")
Kent Cooper, AIA
carminatithekid1
Thanks Kent! I appreciate it. I haven't had the time to learn a lot about lisp but I will be taking classes soon to learn. I appreciate all your guys' help.
If you know of any good sites to assist me, I would greatly appreciate it. I am wanting to learn the most simple, yet basic, way of coding. I am wanting to update all of our coding due to the new method of work and new requests from designers.
Thanks again.
Randy Carminati
