drawing extents
drawing extents
sudarsann
drawing extents
sudarsann
how can i get the drawing extents (lower left corner of the drawing and upper right corner of the drawing) in model space by using the lisp.
When I enter the "status" command in the drawing, text screen shows like this.
I need only "Model space uses" points only. Is it possible to take in autolisp?
Model space limits are X: 0.00000000 Y: 0.00000000 (Off)
X: 12.00000000 Y: 9.00000000
Model space uses X: 10554.55628992 Y: -1086.68058065 **Over
X: 17462.60897057 Y: 4447.29852751 **Over
Display shows X: 7489.73548668 Y: -1111.20781536
X: 20527.71340162 Y: 5283.01580322
Insertion base is X: 0.00000000 Y: 0.00000000 Z: 0.00000000
Snap resolution is X: 0.50000000 Y: 0.50000000
Grid spacing is X: 0.50000000 Y: 0.50000000
I need only "Model space uses" points only. Is it possible to take only "Model space uses" points using autolisp?
Regards
Sudarsan
ВeekeeCZ
These values are stored as system variables EXTMIN and EXTMAX.
(getvar 'EXTMIN)
(getvar 'EXTMAX)
