Thank you a lot for helping me.
I have this lisp, that creates different shapes of cups, but i want to replace circles to squares. With the intention to have a lisp that creates different shapes of towers.
;lisp that makes cups but i want to change to a tower
(defun c:tower ()
(setq pontos2d (getvar "osmode"))
(setq pontos3d (getvar "3dosmode"))
(setvar "osmode" 0)
(setvar "3dosmode" 0)
(command "ucs" (getpoint "Insert point. ") "")
(setq nu 0)
(command "_circle" (list 0 0 0) 1) ;first circle
(guardar)
(command "_circle" (list 0 0 (alea 1 2)) (alea 1 4))
(guardar)
(command "_circle" (list 0 0 (alea 2 7)) (alea 1 1.5))
(guardar)
(command "_circle" (list 0 0 10) 1.5) ;last circle
(guardar)
(solido)
(setq lista nil)
(setvar "osmode" pontos2d)
(setvar "3dosmode" pontos3d)
(command "ucs" "")
(defun guardar ()
(setq lista (append lista (list (set (read (strcat "entidade" (rtos nu))) (entlast)))))
(defun solido ()
(command "loft" "_mo" "_su")
(foreach p lista (command p))
(command "" "")
(defun alea ( min max / )
(+ min (valor (- max min)))
(defun valor (num)
(* num (rnd))
(defun rnd (/ modulus multiplier increment random)
(if (not seed)
(setq seed (getvar "DATE"))
(setq modulus 65536
multiplier 25173
increment 13849
seed (rem (+ (* multiplier seed) increment) modulus)
random (/ seed modulus)
