I want to change circles to squares in this lisp
ritagarciabrito
ritagarciabrito
Thank you a lot for helping me.
I have this lisp, that creates different shapes of cups, but i want to replace circles to squares. With the intention  to have a lisp that creates different shapes of towers.
;lisp that makes cups but i want to change to a tower
(defun c:tower ()
(setq pontos2d (getvar "osmode"))
(setq pontos3d (getvar "3dosmode"))
(setvar "osmode" 0)
(setvar "3dosmode" 0)
(command "ucs" (getpoint "Insert point. ") "")
(setq nu 0)
(command "_circle" (list 0 0 0) 1) ;first circle
(guardar)
(command "_circle" (list 0 0 (alea 1 2)) (alea 1 4))
(guardar)
(command "_circle" (list 0 0 (alea 2 7)) (alea 1 1.5))
(guardar)
(command "_circle" (list 0 0 10) 1.5) ;last circle
(guardar)
(solido)
(setq lista nil)
(setvar "osmode" pontos2d)
(setvar "3dosmode" pontos3d)
(command "ucs" "")
(defun guardar ()
(setq lista (append lista (list (set (read (strcat "entidade" (rtos nu))) (entlast)))))
(defun solido ()
(command "loft" "_mo" "_su")
(foreach p lista (command p))
(command "" "")
(defun alea ( min max / )
(+ min (valor (- max min)))
(defun valor (num)
(* num (rnd))
(defun rnd (/ modulus multiplier increment random)
(if (not seed)
(setq seed (getvar "DATE"))
(setq modulus 65536
multiplier 25173
increment 13849
seed (rem (+ (* multiplier seed) increment) modulus)
random (/ seed modulus)
hak_vz
In your lisp simply change command CIRCLE with command RECT
This creates rectangle with center at point 0 0 0
(command
"_.rectang"
(polar '(0 0 0) (/ pi 4) (* -0.5 (sqrt 2)))
(polar '(0 0 0) (/ pi 4) (* 0.5 (sqrt 2)))
Play with it as you like, change (sqrt 2) with adequate rectangle half diagonal value
Miljenko Hatlak
calderg1000
Regards @ritagarciabrito
Try this code with some small changes.
If I'm not mistaken in any value of the lists, it should work...
(defun c:towerR ()
  (setvar "osmode" 0)
  (setq nu 0)
;;;(command "_circle" (list 0 0 0) 1) ;first circle
  (command "_rectangle" (list -1 -1 0) (list 1 1 0))
  (guardar)
;;;(command "_circle" (list 0 0 (alea 1 2)) (alea 1 4))
  (command
    "_rectangle"
    (list (* -1 (setq a (alea 1 4))) (* -1 (setq b a)) (setq c (alea 1 2)))
    (list a b c)
  (guardar)
;;;(command "_circle" (list 0 0 (alea 2 7)) (alea 1 1.5))
  (command
    "_rectangle"
    (list (* -1 (setq a (alea 1 1.5))) (* -1 (setq b a)) (setq c (alea 2 7)))
    (list a b c)
  (guardar)
;;;(command "_circle" (list 0 0 10) 1.5) ;last circle
  (command "_rectangle" (list -1.5 -1.5 10.) (list 1.5 1.5 10.))
  (guardar)
  (solido)
  (setq lista nil)
  (command "ucs" "")
(defun guardar ()
(defun solido ()
(command "" "")
(defun valor (num)
(* num (rnd))
(if (not seed)
(setq modulus 65536
multiplier 25173
increment 13849
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
