I want full degree mints and second format (DDMMSS) IN TABLE
hiraram_prajapati
Message 1 of 16
hiraram_prajapati
Please help me and edit my lisp I have attached.
(defun c:tabord (/ aCen cAng cCen cPl cRad cReg
fDr it lCnt lLst mSp pCen pT1
pT2 ptLst R tHt tLst vlaPl vlaTab
vLst cTxt oldCol nPl clFlg *error*)
  (vl-load-com)
  (defun Extract_DXF_Values(Ent Code)
    (mapcar 'cdr
     (vl-remove-if-not
      '(lambda(a)(=(car a)Code))
(entget Ent)))
    ); end of
  (defun *error*(msg)
    (setvar "CMDECHO" 1)
    (princ)
    ); end of *error*
  (if
    (and
      (setq cPl(entsel "\nSelect LwPoliline > "))
      (= "LWPOLYLINE"(car(Extract_DXF_Values(car cPl)0)))
      ); end and
(progn
  (setq vlaPl(vlax-ename->vla-object(car cPl))
ptLst(mapcar 'append
       (setq vLst(Extract_DXF_Values(car cPl)10))
       (mapcar 'list(Extract_DXF_Values(car cPl)42)))
lLst '("START POINT" "IP-01" "IP-02" "IP-03" "IP-04" "IP-05" "IP-06" "IP-07" "IP-08" "IP-09" "IP-10" "IP-11" "IP-12""IP-13" "IP-14" "IP-15" "IP-16" "IP-17" "IP-18" "IP-19" "IP-20" "IP-21" "IP-22" "IP-23" "IP-24" "IP-25" "IP-26" "IP-27" "IP-28" "IP-29" "IP-30" "IP-31" "IP-32" "IP-33" "IP-34" "IP-35" "IP-36" "IP-37" "IP-38" "IP-39" "IP-40" "IP-41" "IP-42" "IP-43" "IP-44" "IP-45" "IP-46" "IP-47" "IP-48" "IP-49" "IP-50" "IP-51" "IP-52" "IP-53" "IP-54" "IP-55" "IP-56" "IP-57" "IP-58" "IP-59" "IP-60" "IP-61" "IP-62" "IP-63" "IP-64" "IP-65" "IP-66" "IP-67" "IP-68" "IP-69" "IP-70" "IP-71" "IP-72" "IP-73" "IP-74" "IP-75" "IP-76" "IP-77" "IP-78" "IP-79" "IP-80" "IP-81" "IP-82" "IP-83" "IP-84" "IP-85" "IP-86" "IP-87" "IP-88" "IP-89" "IP-90" "IP-91" "IP-92" "IP-93" "IP-94" "IP-95" "IP-96" "IP-97" "IP-98" "IP-99" "IP-100" "IP-101" "IP-102" "IP-103" "IP-104" "IP-105" "IP-106" "IP-107" "IP-108" "IP-109" "IP-110")
r 2 lCnt 0
;tLst '((1 0 "Point")(1 1 "EASTING")(1 2 "NORTHING")(1 3 "Radius"))
tLst '((1 0 "Point")(1 1 "EASTING")(1 2 "NORTHING")(1 3 "Radius")(1 4 "Distance")(1 5 "Bend"))
mSp(vla-get-ModelSpace
     (vla-get-ActiveDocument
       (vlax-get-acad-object)))
tHt(getvar "TEXTSIZE")
    ); end setq
    (setvar "CMDECHO" 0)
    (setq prVert nil)
    (setq prAng nil)
    (setq ct 0)
    (foreach vert ptLst
      (setq vert(trans vert 0 1))
;;;       (if prVert
;;; (progn
;;;   (setq vDist (rtos (distance prVert vert) 2 4))
;;;;;;   (setq tAng (cvunit (angle prVert vert) "radian" "degree"))
;;;;;;   (setq vAng (rtos tAng  2 0))
;;;;;;   (if prAng
;;;;;;     (progn
;;;;;;       (if (> tAng prAng)
;;;;;; (progn
;;;;;;   (setq vAng (- tAng prAng))
;;;;;;   (if (> vAng 180.0)
;;;;;;     (setq vAng (- vAng 180.0))
;;;;;;   (if (> vAng 90.0)
;;;;;;     (setq vAng (- vAng 90.0))
;;;;;;   (setq vAng (rtos vAng 2 0))
;;;;;;   (setq vAng (strcat "LT " vAng "%%d"))
;;;;;; (progn
;;;;;;   (setq vAng (- prAng tAng))
;;;;;;   (setq vAng (strcat "RT " vAng "%%d"))
;;; (progn
;;;   (setq vDist "0.0")
;;;   (setq vAng "-")
;;;       (setq prAng tAng)
      (if (/= ct 0)
(if (/= ct (- (length ptLst) 1 ))
  (progn
    (setq p1 (nth (- ct 1) ptLst))
    (setq p3 (nth (+ ct 1) ptLst))
    (setq vDist (rtos (distance p1 vert) 2 4))
    ;;EXCEL LOGIC START
;;;     (setq dx (- (car vert) (car p1)))
;;;     (setq dy (- (car (cdr vert)) (car (cdr p1))))
;;;     (setq ang1 (cvunit (angle p1 vert) "radian" "degree"))
;;;     (if (> ang1 180.0000001)
;;;       (setq ang1 (- ang1 360))
;;;     (setq ang1 (calculateAngle dx dy ang1))
;;;     (setq dx (- (car p3) (car vert)))
;;;     (setq dy (- (car (cdr p3)) (car (cdr vert))))
;;;     (setq ang2 (cvunit (angle vert p3) "radian" "degree"))
;;;     (if (> ang2 180.000001)
;;;       (setq ang2 (- ang2 360))
;;;     (setq ang2 (calculateAngle dx dy ang2))
;;;     (if (< (- ang2 ang1) 180.0000001)
;;;       (setq vang (+ (- ang2 ang1) 180))
;;;       (IF (> (- ang2 ang1) 180.0000001)
;;; (setq vang (- (- ang2 ang1) 180))
;;;     (if (< vang 180.0000001)
;;;       (progn
;;; (if (> vang 90.0000001)
;;;   (setq vang (strcat "LT" (rtos (abs (- 180 vang)) 2 0)))
;;;   (if (< vang 0.0)
;;;     (progn
;;;       (setq vang (abs (+ 360 vang)))
;;;       (if (> vang 180.0000001)
;;; (setq vang (- vang 180.0))
;;; (setq vang (- 180 vang))
;;;       (setq vang (strcat "LT" (rtos vang 2 0)))
;;;     (setq vang (strcat "LT" (rtos (abs vang) 2 0)))
;;;       (progn
;;;   (setq vang (strcat "RT" (rtos (ABS (- 180 vang)) 2 0)))
;;;   (setq vang (strcat "RT" (rtos (ABS (- vang 180)) 2 0)))
    ;;EXCEL LOGIC END
    (IF (= ang1 0.00)
(setq ang1 360.0)
      (if (= ang2 0.00)
(if (> ang1 180.00001)
  (setq ang2 360.00)
;;;     (IF (= ang2 360)
;;;       (setq ang2 0.0)
    (if (> ang2 ang1)
(progn
  (if (> ang1 270.0000001)
  (if (> ang2 270.00000001)
  (setq vAng (abs (- ang2 ang1)))
  (if (>= vAng 270.00000001)
    (setq vAng (abs (- vAng 360.0)))
  (if (>= vAng 180.000000001)
  (if (> vAng 90.000001)
(progn
  (if (> ang1 270.0000000001)
  (setq vAng (abs(- ang1 ang2)))
  (if (>= vAng 270.000000001)
  (if (>= vAng 180.0000000001)
  (progn
    (setq vAng "-")
(progn
  (setq vDist "0.000")
  (setq vAng "-")
      (setq tLst(append tLst
  (list(list r 0 (nth lCnt lLst))
  (list r 1(rtos(car vert)2 4))
  (list r 2(rtos(cadr vert)2 4))
  (list r 3 "")
  (list r 4 vDist)
  (list r 5 vAng))))
      (if(and
   (/= 0.0(last vert))
    (setq pt1(vlax-curve-GetPointAtParam vlaPl lCnt))
    (setq pt2(vlax-curve-GetPointAtParam vlaPl(1+ lCnt)))
   ); end and
(setq r(1+ r)
      cRad(abs(/(distance pt1 pt2)
  2(sin(/(* 4(atan(abs(last vert))))2))))
      aCen(vlax-curve-GetPointAtParam vlaPl(+ 0.5 lCnt))
      fDr(vlax-curve-getFirstDeriv vlaPl
   (vlax-curve-getParamAtPoint vlaPl aCen))
      pCen(trans
    (polar aCen(-(if(minusp(last vert)) pi(* 2 pi))
      (atan(/(car fDr)(cadr fDr))))cRad)0 1)
      tLst(append tLst(list
    (list r 0 "center")
    (list r 1(rtos(car pCen)2 4))
    (list r 2(rtos(cadr pCen)2 4))
    (list r 3(rtos cRad 2 4))))
      ); end setq
); end if
      (setq r(1+ r) lCnt(1+ lCnt))
      (setq prVert vert)
      (setq ct (1+ ct))
      ); end foreach
;;;   (setq vlaTab(vla-AddTable mSp (vlax-3D-point '(0 0 0))
;;; (+ 1(/(length tLst)4)) 4 (* 3 tHt)(* 18 tHt)))
(+ 1(/(length tLst)6)) 6 (* 3 tHt)(* 18 tHt)))
  (foreach i tLst
    (vl-catch-all-apply 'vla-SetText(cons vlaTab i))
    (vla-SetCellTextHeight vlaTab(car i)(cadr i)tHt)
    (vla-SetCellAlignment vlaTab(car i)(cadr i)acMiddleCenter)
    ); end foreach
  (vla-DeleteRows vlaTab 0 1)
  (princ "\n<<< Place Table >>> ")
  (command "_.copybase" (trans '(0 0 0)0 1)(entlast) "")
  (command "_.erase" (entlast) "")
  (command "_.pasteclip" pause)
  (if(= :vlax-true(vla-get-Closed vlaPl))
    (progn
     (setq nPl(vla-Copy vlaPl))
     (command "_.region" (entlast) "")
     (setq cCen(vlax-get(setq cReg
(vlax-ename->vla-object(entlast)))'Centroid))
      (vla-Delete cReg)
      (setq clFlg T)
     ); end progn
    ); end if
  (setq lCnt 0)
  (foreach v vLst
    (if clFlg
     (setq cAng(angle cCen(trans v 0 1))
           iPt(polar v cAng (* 2 tHt)))
      (progn
(setq fDr(vlax-curve-getFirstDeriv vlaPl (vlax-curve-getParamAtPoint vlaPl v)))
(if (or (= (car fDr) 0) (= (cadr fDr) 0))
  (setq iPt(trans (polar v (- (* 2 pi) (atan (* 5 tHt))) (* 2 tHt))0 1))
  (setq iPt(trans (polar v (- (* 2 pi) (atan (/ (car fDr) (cadr fDr)))) (* 2 tHt))0 1))
     ); end Progn
      ); end if
    (setq cTxt(vla-AddText mSp(nth lCnt lLst)
       (vlax-3d-point iPt) tHt)
  lCnt(1+ lCnt)
  ); end setq
    (setq oldCol(getvar "CECOLOR"))
    (setvar "CECOLOR" "1")
    (command "_.circle" v (/ tHt 3))
    (setvar "CECOLOR" oldCol)
    ); end foreach
  ); end progn
     (princ "\n<!> It isn't LwPolyline! Quit. <!> ")
    ); end if
    (princ)
    ); end of c:tabord
(defun calculateAngle (dx dy ang)
  (setq retVal 0)
  (If (and (< dx 0) (>= dy 0))
    (setq retVal (- ang 450))
    (if (and (>= dx 0) (>= dy 0))
      (setq retVal (- ang 90))
      (if (and (< dx 0) (< dy 0))
(if (and (>= dx 0) (< dy 0))
  (abs retVal)
  )); end of c:TABORD
Replies (15)
Message 2 of 16
Kent1Cooper
Too much code to wade through in detail [better to attach a file than to include hundreds of lines of code in the Message body, and you should also eliminate the irrelevant commented-out lines], but I think:
Change (rtos) functions involving angles to (angtos) functions [read about those in the AutoLisp Reference].  The first argument after the value to be converted should be 1 to get degrees-minutes-seconds, and the last one should be 4 to go as far as seconds [without decimal places].  The DIMZIN System Variable setting will determine whether trailing zeroes for minutes/seconds will be included.
And you can get a degrees symbol instead of the "d" that (angtos) will supply.
As one example, change this [which occurs more than once]:
(rtos vAng 2 0)
to this:
(vl-string-subst "°" "d" (angtos vAng 1 4))
I'm pretty sure that one is about an angle, but don't know about some others without deeper analysis.  But don't change all (rtos) functions -- not all are about angles.
Kent Cooper, AIA
Message 3 of 16
Moshe-A
@hiraram_prajapati ,
check this correction 😀
enjoy
Moshe
Message 4 of 16
autoid374ceb4990
I cannot load your LISP program (ACAD error: extra right paren), but I have attached a file that may help you format the bearing string.
Just load the BRDIST.LSP file and type "BR" to see how it works.
There is a function in the file called "br_dist" that formats the angle.
I wrote this program over 30 years ago, so I hope it works in the newer AutoCADs.
Message 5 of 16
hiraram_prajapati
Dear Sir,
Thank you for help,
But is changing Easting northing to DDMMSS, I want only in last column as shown in attached snap.
Please try to change in last column not in easting northing.
thanks you
Message 6 of 16
hiraram_prajapati
I am not able to load your lisp and commands not working, please check and reply.
Message 7 of 16
hiraram_prajapati
Dear sir,
I have attached Lisp. please load and type Command ""TABORD"".
Please update and sent me.
Thank you in advance.
Message 8 of 16
Moshe-A
sorry, as this lisp is touched, it stop working at all 😩
Moshe
Message 9 of 16
Kent1Cooper
[There is still an extra right parenthesis somewhere.]
Kent Cooper, AIA
Message 10 of 16
komondormrex
right the last one in original code by op.
Message 11 of 16
komondormrex
as commander Cooper suggested
  (vl-load-com)
    (mapcar 'cdr
     (vl-remove-if-not
	 (entget Ent)))
    ); end of
  (defun *error*(msg)
    (princ)
    ); end of *error*
  (if
    (and
      ); end and
	(progn
		r 2 lCnt 0
		    ); end setq
	    (setq prVert nil)
	    (setq prAng nil)
	    (setq ct 0)
	    (foreach vert ptLst
;;;	      (if prVert
;;;		(progn
;;;;;;		  (if prAng
;;;;;;		    (progn
;;;;;;			(progn
;;;;;;			(progn
;;;		(progn
;;;		  (setq vAng "-")
	      (if (/= ct 0)
		  (progn
		    ;;EXCEL LOGIC START
;;;		      (progn
;;;			    (progn
;;;		      (progn
		    ;;EXCEL LOGIC END
		    (IF (= ang1 0.00)
			(setq ang1 360.0)
		      (if (= ang2 0.00)
			  (setq ang2 360.00)
;;;		      (setq ang2 0.0)
		    (if (> ang2 ang1)
			(progn
			  (setq vAng (vl-string-subst "°" "d" (angtos vAng 1 4)))
			  (setq vAng (strcat "LT " vAng))
			(progn
			  (setq vAng (strcat "RT " vAng))
		  (progn
		    (setq vAng "-")
		(progn
		  (setq vAng "-")
			  (list r 3 "")
			  (list r 4 vDist)
			  (list r 5 vAng))))
	      (if(and
		   (/= 0.0(last vert))
		   ); end and
		(setq r(1+ r)
		      pCen(trans
			    (list r 0 "center")
		      ); end setq
		); end if
	      (setq prVert vert)
	      (setq ct (1+ ct))
	      ); end foreach
	  (foreach i tLst
	    ); end foreach
	    (progn
	      (vla-Delete cReg)
	      (setq clFlg T)
	     ); end progn
	    ); end if
	  (setq lCnt 0)
	  (foreach v vLst
	    (if clFlg
	      (progn
	     ); end Progn
	      ); end if
		  lCnt(1+ lCnt)
		  ); end setq
	    ); end foreach
	  ); end progn
    ); end if
    (princ)
    ); end of c:tabord
  (setq retVal 0)
  (abs retVal)
  ); end of c:TABORD
Message 12 of 16
john.uhden
And if you want the degree character ° then use (chr 176)
John F. Uhden
Message 13 of 16
john.uhden
Enter new value for DIMZIN <8>: 1
Command: (angtos ang 1 4)
"13d0'0\""
Command: (vl-string-subst (chr 176) "d" (angtos ang 1 4))
"13°0'0\""
I have a very old one somewhere to double-up the zeros.  Here it is...
(defun @angdms (ang dsym n)
   (if (= (type ang) 'REAL)
      (setq ang (angtos ang 1 n) n 1)
      (setq n 1)
   (while (/= (substr ang n 1) "d")(setq n (1+ n)))
   (if (= n 2) (setq ang (strcat "0" ang) n 3))
   (setq ang (strcat (substr ang 1 (1- n)) dsym (substr ang (1+ n))))
   (setq n (+ n (1- (strlen dsym))))
   (if (= (substr ang (+ n 2) 1) "'")
      (setq ang (strcat (substr ang 1 n) "0" (substr ang (1+ n))) n (+ n 3))
      (setq n (+ n 3))
   (if (or (= (substr ang (+ n 2) 1) ".")(= (substr ang (+ n 2) 1) (chr 34)))
      (setq ang (strcat (substr ang 1 n) "0" (substr ang (1+ n))))
   ang
As in...
Command: (@angdms ang (chr 176) 4)
"13°00'00\""
John F. Uhden
Message 14 of 16
hiraram_prajapati
Dear Sir,
DDMMSS Format working fine and working fine, But Degree coming wrong.
What i want i shown in Line in magnet color.
I have attached AutoCAD and Image for your reference and correction.
Thank you, please update.
Message 15 of 16
komondormrex
check this another one
(defun vectors_angle (vector_1 vector_2 / x1 y1 z1 x2 y2 z2 ccw cos_a sin_a alpha)
  	(mapcar 'set '(x1 y1 z1) (mapcar '- (cadr vector_1) (car vector_1)))
  	(mapcar 'set '(x2 y2 z2) (mapcar '- (cadr vector_2) (car vector_2)))
	(setq ccw (not (minusp (caddr (list (- (* y1 z2) (* z1 y2)) (- (* z1 x2) (* x1 z2)) (- (* x1 y2) (* y1 x2))))))
		  cos_a (/ (+ (* x1 x2) (* y1 y2) (* z1 z2))
				   (* (sqrt (apply '+ (mapcar '(lambda (number) (expt number 2)) (list x1 y1 z1))))
					  (sqrt (apply '+ (mapcar '(lambda (number) (expt number 2)) (list x2 y2 z2))))
		  sin_a (sqrt (- 1 (expt cos_a 2)))
	(cond
		((zerop cos_a) (cons ccw (* 0.5 pi)))
		((zerop (setq alpha (atan (/ sin_a cos_a)))) (cons nil pi))
		((minusp alpha) (cons ccw (+ pi alpha)))
		(t (cons ccw alpha))
  (vl-load-com)
    (mapcar 'cdr
     (vl-remove-if-not
	 (entget Ent)))
    ); end of
  (defun *error*(msg)
    (princ)
    ); end of *error*
  (if
    (and
    ); end and
	(progn
			       (setq vLst (Extract_DXF_Values (car cPl) 10))
			       (mapcar 'list (Extract_DXF_Values (car cPl )42)))
		r 2 lCnt 0
	  ); end setq
	    (setq prVert nil)
	    (setq prAng nil)
	    (setq ct 0)
	    (foreach vert ptLst
	      (if (/= ct 0)
		  (progn
		    (setq vAng (vectors_angle (list p1 vert) (list vert p3)))
		    (setq vAng (strcat (if (car vAng) "LT" "RT") (vl-string-subst "°" "d" (angtos (cdr vAng) 1 4))))
		  (progn
		    (setq vAng "-")
		(progn
		  (setq vAng "-")
		(print
	      (setq tLst (append tLst
			  (list r 3 "")
			  (list r 4 vDist)
			  (list r 5 vAng)))
	      (if(and
		   (/= 0.0(last vert))
		   ); end and
		(setq r(1+ r)
		      pCen(trans
			    (list r 0 "center")
		      ); end setq
		); end if
	      (setq prVert vert)
	      (setq ct (1+ ct))
	      ); end foreach
	  (setq vlaTab (vla-AddTable mSp (vlax-3D-point '(0 0 0))
			(+ 1(/ (length tLst)6)) 6 (* 3 tHt)(* 18 tHt)))
	  (foreach i tLst
	    (vl-catch-all-apply 'vla-SetText (cons vlaTab i))
	    ); end foreach
	    (progn
	      (vla-Delete cReg)
	      (setq clFlg T)
	     ); end progn
	    ); end if
	  (setq lCnt 0)
	  (foreach v vLst
	    (if clFlg
	      (progn
	     ); end Progn
	      ); end if
		  lCnt(1+ lCnt)
		  ); end setq
	    ); end foreach
	  ); end progn
    ); end if
    (princ)
Message 16 of 16
hiraram_prajapati
Thank you so much help.....
It is working very fine.
