I need lisp opening drawing
Message 1 of 13
Hi all,
I need a lisp that can meet some requirements as below:
1, allow to select path to drawing folder
2, able to open drawing from text in an autocad file by right click or etc.....
3, "key" search is included, no need exactly
Exp drawing number is 1a-12345678, can search and open with key "1a-123456 or 123456"
Thank you all
Replies (12)
Message 2 of 13
john.uhden
@Anonymous
What do you mean by "able to open drawing from text in an autocad file by right click or etc.....?"
Do you mean to find a DWG containing a certain text string?
Or maybe you just mean to be able to type in part of drawing name, say with wildcards, then get a list of matching names to choose from.  I think the AutoCAD OPEN command can do that.
John F. Uhden
Message 3 of 13
pendean
Community Legend
Community Legend
HYPERLINK command is explained in HELP: explore it, it is what you seek.
Message 4 of 13
@john.uhden i mean
In Parts list of assembly drawing, we can see the text that include the part drawing number and i want to open that part drawing directly just by right click on the text and open it. Location to drawings folder is set in step 1.
@pendean hyperlink is not what i mean
Message 5 of 13
john.uhden
What kind of object is the parts list... text, mtext, table, block with attribute(s), OLE, thingamabob?
John F. Uhden
Message 6 of 13
@john.uhden
i sent you an assembly drawing with parts list in it,
look at to row 1, part number BLO-TENS-0000-0003 is also drawing number, i want to open this drawing directly
https://drive.google.com/file/d/1XIp89lxAHfI6rdLSypEJTElCVFYTujoq/view?usp=sharing
Thank you
Message 7 of 13
Sea-Haven
It really does not matter wether a table, text, block etc need to just get the text value, if the library of parts is in support path directory then (command "open" "ABC123-456") will work.
A undocumented fact is support path can include multiple directories without naming them by using double ".."
eg C:\myblocks\.. this will look lower down for block say ABC123-456.
So my recommendation is set support paths.
Message 8 of 13
jwhitleyWQHCV
I opened your test drawing and saw that the text is not an attribute but mtext in a block. This can make it difficult to select, separate from the block, to do a search. I do have a code that can help you a bit though.
(defun ( / path name )
(setq name (getstring "ENTER FILE NAME" ))
(setq path (findf name"C:\\")) ;; change path of C:\\ to narrow search path, doing so may speed things up otherwise it'll search your whole computer
(command "_.open" path)
(defun findf (fnm dir)
(setq dir (vl-string-right-trim
(vl-string-translate "/" "\\" dir)
(cond
((findfile (strcat dir "\\" fnm)))
((vl-some '(lambda (xx) (findf fnm (strcat dir "\\" xx)))
(vl-remove "."
(vl-remove ".." (vl-directory-files dir nil -1))
Message 9 of 13
john.uhden
So sorry, Alan.
You know that I'm way behind the times (2002).  With my coronation I got a free copy of C3D2016, but my laptop is so old and weak that I have a very difficult time doing most anything in C3D.  Anyway, now I see what you mean.  Even if the data is in a table, you can pick on an entry using (nentsel), so I think that's the key.
Ya know if I don't get a job soon and be able to buy a newer computer to be able to run the newer versions I will have little value in these parts.
John F. Uhden
Message 10 of 13
Sea-Haven
Your right about nentsel
(setq txt (cdr (assoc 1 (entget (car (nentsel "\nSelect text"))))))
Message 11 of 13
Sorry all but i can not use any of your code, could please write a completed code for this issue. Thank
Message 12 of 13
john.uhden
@Anonymous
You can use it if you learn.  That's what we are primarily here for... to help you learn, not to provide completed freeware because you are unwilling to learn to create your own.
Boy, do I hate repeating myself.
John F. Uhden
Message 13 of 13
devitg
@Anonymous  AKA
vudungcom
You also  post it at CADTUTOR
https://www.cadtutor.net/forum/topic/71221-i-need-a-lisp-that-can-open-drawing-from-mtext-in-dwg/
