I need a Lisp to copy a number and paste in another object
mmprakash90
Message 1 of 21
mmprakash90
Hi All,
I have a scenario where I need a Lisp program to copy and paste within same DWG
In a DWG I have a number for
EX :123456
And another object like ADD=XXXXXX
Now , I want that 123456 in the place of XXXXXX like ADD= 123456 in just two three clicks
Need your help
Replies (20)
Message 21 of 21
komondormrex
check the following code
(defun c:replace_X-X ( / num_text num_string start_x_pos end_x_pos target_string target_dxf)
	(while (setq num_text (car (entsel "\nPick text with number to get from: ")))
	 	   (setq num_string (cdr (assoc 1 (entget num_text))))
	 		(while (null (setq start_x_pos (acet-str-find "[xX]+"
							(cdr
							  (cond
							     ((setq target_string_group
				  				  	(assoc 1 (setq target_dxf
											(entget (car (entsel (strcat "\nPick text to replace \"X...X\" with \""
															  num_string
							      ((setq target_string_group (assoc 304 target_dxf)))
					  		  ) t t
							end_x_pos start_x_pos
	 		  (entmod (subst (cons (car target_string_group) (vl-string-subst
					 					num_string
					 					(substr (cdr target_string_group)
				 								start_x_pos
												(progn
												  (while (or (= "X" (substr (cdr target_string_group) (setq end_x_pos (1+ end_x_pos)) 1))
													     (= "x" (substr (cdr target_string_group) end_x_pos 1))
												  (- end_x_pos start_x_pos)
					target_string_group
					target_dxf
	 (princ)
