I'm looking to incorporate a LISP command into a dynamic block
cclawsonD6QHU
Message 1 of 32
cclawsonD6QHU
So I'm very new to LISP Commands and think I have something that will do what I want it to do, however I want it inside a dynamic block that will update as I stretch it, (basically I want to associate a line with a divide command making equal parts at or under 12" on center) I have no idea how to do that, so any help would be greatly appreciated. (the line in question is the gray line with the drill holes on each end)
Attached are both the block and LISP
thanks
Replies (31)
Message 21 of 32
Moshe-A
@cclawsonD6QHU ,
thanks you for that, i found a bug and fix it - file attached
Message 22 of 32
Moshe-A
@Sea-Haven hi,
Excellent idea Allen, love it 🙏 thank you
Moshe
Message 23 of 32
cclawsonD6QHU
so from what I understand of that code is should work for any future blocks so long as I use the same layers and add the block name to the setq MA?
also they just changed those drill holes to 3/16" so should I change the
(setq radius-feet (/ 1 16 12.0)) ; 1/16 inch expressed as feet to
(setq radius-feet (/ 3 32 12.0)) ; 3/32 inch expressed as feet?
Thanks again so much you are awesome?
Message 24 of 32
Moshe-A
yes
but in order to make it support multiple blocks, multiple layers  i need to make more changes.
Message 25 of 32
cclawsonD6QHU
so it wouldn't just work if I  changed
; define some const globals
(setq MA:BLKNAME "square panel") ; const
(setq MA:DRILL_LINE_LAYER "guide lines") ; const
(setq MA:DRILL_HOLES_LAYER "+drill holes") ; const
to
(setq MA:BLKNAME "corner panel") ; const
and just add the new block?
sorry if my questions seem dumb I'm trying to learn it as well as have it work lol.
I'm taking a course on it but so far It hasn't touched on anything to do with blocks.
Thanks again you are so super helpful.
Message 26 of 32
Moshe-A
@cclawsonD6QHU  hi,
Here is an update to support multiple blocks as multiple layers.
A new variable (the 3 previous gone  😀) called MA:DATALIST, list of items each has 3 strings where first string is block name,
second string is layer for lines, third string is layer for drills.
you can add more blocks and layers. it is important not to break the format (if you do? it won't work)
                                       ; block name      guide line    drill hole
(setq MA:DATALIST '(("square panel" "guide lines" "+drill holes")
                                     ("corner panel" "guide lines" "+drill holes")
                                  ); list
); setq
Moshe
Message 27 of 32
cclawsonD6QHU
I see... Thank you for that I will go over the new code and see if I can understand exactly what you did to make it work thank you so much for your help!
to clarify I would need to alter this bit to add more blocks?
("angled panel" "guide lines" "+drill holes")
   ); list
); setq
Message 28 of 32
Moshe-A
yes exactly
Message 29 of 32
cclawsonD6QHU
great you are a god send! seriously your help has saved me an unholy amount of time.
Message 30 of 32
Moshe-A
found 2 more bugs  😩 now fixed 💪
Message 31 of 32
cclawsonD6QHU
thank you so much! I have it working for all the different panels now and it saves so much time and chance of error.
Message 32 of 32
cclawsonD6QHU
So I've been doing a bit of research and I think I've come up with a plausible solution to my new problem. however I'm unsure whether It will fully work as I have yet to figure it out...  my need is to add weep holes at the center line of the drill holes on the bottom of selected panels only. the idea is to use the y axis to limit the command to only work on the guide lines on the 0 y coordinates for example, and then just make sure all panels that require the weep holes fall onto that plane... my major issue is the actual code, as I've been unable to find an example to follow, that deals with both the y constraint and putting something centered between two center points... if you know of a sight or video that would help me figure it out that would be much appreciated or even an explanation would do.
Thanks.
