I am still unable to get slide library images to view?
DC-MWA
Message 1 of 27
DC-MWA
Hello all,
I am back again with this routine. Despite my efforts and input from others I am still unable to get the slide library to display images. It's not the end of the world but having dozens of separate slide files to babysit is kind of a pain.
Wondering if I could get some more input from the gurus to assist me with this.
The lisp and the slide library file are attached.
Thanks in advance for your assistance.
-DC
Replies (26)
Message 21 of 27
Moshe-A
@DC-MWA,
Ha now i'm getting you, 'repeat command \ repeat image' is all summed up as store the last selected item and retrieve it at start as default - Right?!
to store the selected item you can write it to registry immediately after selecting OK:
(defun save_registry_string (KEY value / reg-key)
  (setq reg-key (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Applications\\mwa\\walladd"))
  (vl-registry-write reg-key KEY value)
usage:
(save_registry_string "selLst_item" selLst_item)
to retrieve registry value:
(defun restore_registry_string (KEY def / reg-key value)
  (if (setq value (vl-registry-read reg-key KEY))
   value
   (vl-registry-write reg-key KEY def)
if 'KEY' is not exist, it will be created with 'def' value.
usage:
(setq selLst_item (restore_registry_string "selLst_item" "0"))
so you call (restore_registry_string) before opening the dialog box, than inside (while) set tiles default value (that's include populate the list, show your logo, show the image, highlight list item and set the bottom message). when list item is selected\changed respond to it by showing the selected image plus set the bottom message. when OK picked, after you execute (command) call (save_registry_string).
Attached the modified lisp 😀
enjoy
moshe
Message 22 of 27
DC-MWA
Hi Moshe,
Dude... this is awesome!
For some reason it ignores the faster repeat command (command "-walladd") and always uses the long version (command "-walladd" "h" pause "st" (ret_list_item car selLst_item)).
Other than that this program is awesome, fast, easy to use.
-dc
Message 23 of 27
Moshe-A
@DC-MWA ,
hallelujah!!!
why do you call (command "-walladd") repeat command? isn't it a command to draw a wall?
anyway according the code below you will reach the short version only if no list item is selected $value=""
if you want something else you have to write the exact code. so what is the condition it should run the short version?
(if (eq selLst_item "")
moshe
Message 24 of 27
DC-MWA
When the user hits ok or enter without selecting from list, it should run the short version.
When the user actually selects from the list it should run the long version.
Message 25 of 27
Moshe-A
yes, but now what you have is default setting so there is no condition without selected item
if you want to deselect the highlight item call:
(set_tile "lst" "")
Message 26 of 27
DC-MWA
With brief testing that seems to have done the trick.
Moshe... I have to say again... I truly appreciate your time and patience. I am going to fine tune my two other programs that are similar to this one using what I've learned here with you.
Thank you, thank you, thank you!!!!
-DC
Message 27 of 27
Moshe-A
@DC-MWA ,
You are most welcome 😀
i'm sure you learned a lot from this 'exercise' and you will take it ON and even teach other young Lispers in the short future.
Have nice Weekend
Moshe
