AUTOSAVE REACTOR
AUTOSAVE REACTOR
Message 1 of 10
AUTOSAVE REACTOR
I am using the following lisps to save my drawing every 50th command. Can it be modified to not count 'undo' commands? Reason being: if this tries to save when an undo command is used, something goes wrong and Autocad hangs up and will not work through the issue or conflict.
(if
  (null *autosave-reactor*)
  (setq *autosave-reactor*
(vlr-command-reactor "autosave"
'( (:vlr-commandended . autosave)
(:vlr-commandcancelled . autosave)
(:vlr-commandfailed . autosave)
) ) (setq *autosave-acdoc* (vla-get-activedocument (vlax-get-acad-object) ) ; current dwg file   *autosave-count* 0 ; command counter start point ) (defun autosave ( obj arg )   (if     (and (zerop (rem (setq *autosave-count* (1+ *autosave-count*) ) 50) ) ; Change #50 to change the number of commands performed between saves.     (= 1 (getvar 'dwgtitled) )
)     (vla-save *autosave-acdoc*)   )   (princ) )
Replies (9)
Message 2 of 10
ronjonp
Add this:
(defun autosave	(obj arg)
  (if (and (not (wcmatch (car arg) "U,UNDO"))
	   (zerop (rem (setq *autosave-count* (1+ *autosave-count*)) 50))
	   (= 1 (getvar 'dwgtitled))
  (princ)
Message 3 of 10
Thank you RONJONP, that worked.
Message 4 of 10
ronjonp
Glad to help ; - )
Message 5 of 10
mviscettoVGK6V
Are you having success with your Lisp routine?
I am struggling with a couple users losing work. Not saving as they should.
And, as much as I am working on correcting the bad habits, I really would like to eliminate the "Lost Work" issue.
Thank you
MV
Message 6 of 10
pendean
Community Legend
Community Legend
@mviscettoVGK6V "slip manager cap on" are your users really losing work? or is that a good excuse to not perform the work in the first place? "slip manager cap off"
Reactor works great, give it a try: I'd be surprised if it solve the issue with those two users (dang, manager cap is still in my hand).
HTH
Message 7 of 10
marko_ribar
Thank you
MV
I know this is an old topic, but I've took some time to code for a solution for this very important issue...
(defun c:autosave-reactor-ON nil
  (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com))
  (if (not *autosave-reactor*)
  (defun _nextchr ( character reverseflag / a ) ;;; character - either integer representing (ascii chr), or string representing character - (= (strlen character) 1)
    (if (eq (type (setq a character)) 'str)
      (setq a (ascii a))
    (cond
      ( (< 47 a 58)
        (cond
          ( (= a 57)
            (if reverseflag 56 65)
          ( (= a 48)
            (if reverseflag 122 49)
      ( (< 64 a 123)
        (cond
          ( (= a 122)
            (if reverseflag 121 48)
          ( (= a 65)
            (if reverseflag 57 66)
    (setq a (if reverseflag (1- a) (1+ a)))
    (if (eq (type character) 'str)
      (chr a)
      a
  (defun _incrementstring ( string reverseflag / _process _process_increment l a )
    (defun _process ( l reverseflag / a ) ;;; l = reverse list of ascii string characters
      (if l
        (cond
          ( (= 122 (setq a (car l)))
            (if reverseflag (cons 121 (cdr l)) (cdr l))
          ( (= 48 a)
            (if reverseflag (cdr l) (cons 49 (cdr l)))
          ( t
            (cons (_nextchr a reverseflag) (cdr l))
    (defun _process_increment ( l reverseflag / a ) ;;; l = reverse list of ascii string characters
      (if (setq a (_process l reverseflag))
        (if (= (length a) (length l))
          a
          (cons (if reverseflag 122 48) (_process_increment a reverseflag))
    (if (/= (length (setq a (_process_increment (reverse (vl-string->list string)) reverseflag))) (strlen string))
      (setq l (if reverseflag (cons 122 a) (cons 48 a)))
      (setq l a)
    (vl-list->string (reverse l))
  (defun autosave ( obj arg / olddwgname name newdwgname fn ct lwt lat )
    (if
      (and
        (not (wcmatch (car arg) "U,UNDO,ZOOM,PAN"))
        (zerop (rem (setq *autosave-count* (1+ *autosave-count*)) *autosave-setting*)) ;;; Change #50 to change the number of commands performed between saves.
        (or
          (= 1 (logand 1 (getvar 'dbmod)))
          (= 32 (logand 32 (getvar 'dbmod)))
      (progn
        (setq olddwgname (strcat (getvar 'dwgprefix) (getvar 'dwgname)))
        (setq name (vl-filename-base (getvar 'dwgname)))
        (while (findfile (setq newdwgname (strcat (getvar 'dwgprefix) name "_" (setq *autosave-suffix* (if *autosave-suffix* (_incrementstring *autosave-suffix* nil) (_incrementstring *suffix* nil))) ".dwg")))) ;;; reverseflag = nil (NO REVERSE LAST CHAR FOR INCREMENTATION)
        (vla-saveas *autosave-acdoc* newdwgname)
        (vl-file-copy olddwgname (strcat name "_tmp.dwg"))
        (vla-saveas *autosave-acdoc* olddwgname)
        (if (and (not *flg*) (setq *flg* (findfile (strcat name ".bak"))))
          (vl-file-rename (strcat name ".bak") (strcat name "_old.dwg"))
        (vl-file-copy (strcat name "_tmp.dwg") olddwgname)
        (vl-file-delete (strcat name "_tmp.dwg"))
    (princ)
  (setq *autosave-acdoc* (vla-get-activedocument (vlax-get-acad-object)) ;;; current dwg file
        *autosave-count* 0 ;;; command counter start point
  (initget 6)
  (setq *autosave-setting*
    (cond
      ( (getint "\nSpecify autosaving reactor reaction after < 30 > processed commands without - U,UNDO,ZOOM,PAN (input integer number) : ") )
      ( 30 )
  (or *suffix* (/= (setq *suffix* (getstring "\nSpecify suffix to be added at the end of autosave files after _ <\"00000000\"> : ")) "") (setq *suffix* "00000000"))
  (princ)
(defun c:autosave-reactor-OFF nil
  (if *autosave-reactor*
    (vlr-remove *autosave-reactor*)
  (mapcar (function (lambda ( x ) (set x nil))) '(*autosave-acdoc* *autosave-count* *autosave-setting* *autosave-suffix* *suffix* *flg* *autosave-reactor* _nextchr _incrementstring autosave))
  (princ)
HTH. M.R.
Regards...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 8 of 10
mviscettoVGK6V
Good morning Dean,
An excuse to have not done the work in the first place?
Whaaaaaaat? Nobody would really do that would they?
Wishful thinking, right?!
I had a guy who actually used "My computer just shut down for no reason and I lost all that work" blah blah blah........
Drives me nuts.😠
Hope all is good with you and yours.
Be Well.
Michael Viscetto
Message 9 of 10
marko_ribar
Just to inform that I had some blunders in (_nextchr) sub function... Now it's fixed... You can copy+paste the code now as I have updated it...
Also some other minor changes...
Regards, M.R.
Message 10 of 10
mviscettoVGK6V
Marko
Can you please paste your updated autosave_reactor here?
