how use loop when list element only one
avinash00002002
avinash00002002
I have some list in which has only one element, how to run loop
(("Hole2" . 18))
if more than one we can use
(repeat (setq i (1- (length lst1)))
but for one element it gives error.
Avinash
ВeekeeCZ
Because you need to loop it "length-times", not len-1 times
If length of your lst1 is 1, then (1- (length lst1)) is 0, so it runs 0-times
(defun c:test ()
  (setq lst1 '(("Hole2" . 18)))
  (repeat (setq i (length lst1)) ; length of entire list
    (print
      (nth (setq i (1- i)) lst1) ; last index is length-1
  (princ)
calderg1000
Regards @avinash00002002
When you have a single element in your list, it is not necessary to apply a loop, since in advance you can know that the position it occupies within the list is i = 0
Here I show you some examples to get the only item on your list.
(setq lst'(("Hole2" . 18)))
1. Option
(setq elist(nth 0 lst))
2. Option
(setq elist(car lst))
3. Option
(setq elist(last lst))
4. Option
(repeat (setq i (length lst))
(setq elist (nth (setq i(1- i)) lst)))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
