- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
There is a lisp which was downloaded a while ago. I do not know how to use it now. Could you please provide some advice to me? Please see attached lisp, it was pasted below as well, thank you very much in advance. 🙂
;;; By Dominic Panholzer
;;; Modified original TXTEXP.LSP from Express Tools
;;; Copyright © 1999 by Autodesk, Inc.
;; LINEXP.LSP modifications by CAD Studio
;;; Your use of this software is governed by the terms and conditions of the
;;; License Agreement you accepted prior to installation of this software.
;;; Please note that pursuant to the License Agreement for this software,
;;; "[c]opying of this computer program or its documentation except as
;;; permitted by this License is copyright infringement under the laws of
;;; your country. If you copy this computer program without permission of
;;; Autodesk, you are violating the law."
;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;; UNINTERRUPTED OR ERROR FREE.
;;; Use, duplication, or disclosure by the U.S. Government is subject to
;;; restrictions set forth in FAR 52.227-19 (Commercial Computer
;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;; (Rights in Technical Data and Computer Software), as applicable.
;;; External Functions:
;;; ACET-ERROR-INIT --> ACETUTIL.FAS Intializes bonus error routine
;;; ACET-ERROR-RESTORE --> ACETUTIL.FAS Restores old error routine
;;; ACET-GEOM-ZOOM-FOR-SELECT --> ACETUTIL.FAS Zoom boundry to include points given
;;; ACET-LAYER-LOCKED --> ACETUTIL.FAS Checks to see if layer is locked
;;; ACET-GEOM-PIXEL-UNIT --> ACETUTIL.FAS Size of pixel in drawing units
;;; ACET-GEOM-TEXTBOX --> ACETUTIL.FAS Returns the textbox for any text
;;; ACET-GEOM-MIDPOINT --> ACETUTIL.FAS Returns midpoint between two points
;;; ACET-GEOM-VIEW-POINTS --> ACETUTIL.FAS Returns corner points of screen or viewport
;;; ACET-STR-FORMAT --> ACETUTIL.ARX String builder
;;; ACET-WMFIN --> ACETUTIL.FAS Brings in WMF file
(defun c:linexp (/ grplst getgname blknm FLTR GLST GDICT SS VIEW UPLFT TMPFIL TBX
TMPFIL CNT PT1 PT2 ENT TXT TXTYP PTLST ZM LOCKED GNAM vpna vplocked)
(acet-error-init
(list
(list "cmdecho" 0
"highlight" 1
"osmode" 0
"Mirrtext" 1
"limcheck" 0
T
; --------------------- GROUP LIST FUNCTION ----------------------
; This function will return a list of all the group names in the
; drawing and their entity names in the form:
; ((<ename1> . <name1>) ... (<enamex> . <namex>))
(defun acet-txtexp-grplst (/ GRP ITM NAM ENT GLST)
(setq GRP (dictsearch (namedobjdict) "ACAD_GROUP"))
(while (setq ITM (car GRP)) ; While edata item is available
(if (= (car ITM) 3) ; if the item is a group name
(setq NAM (cdr ITM) ; get the name
GRP (cdr GRP) ; shorten the edata
ITM (car GRP) ; get the next item
ENT (cdr ITM) ; which is the ename
GLST ; store the ename and name
(if GLST
(append GLST (list (cons ENT NAM)))
(setq GRP (cdr GRP)) ; else shorten the edata
GLST ; return the list
; ------------------- GET GROUP NAME FUNCTION --------------------
; This function returns a list of all the group names in GLST
; where ENT is a member. The list has the same form as GLST
(defun acet-txtexp-getgname (ENT GLST / GRP GDATA NAM NLST)
(if (and GLST (listp GLST))
(progn
(foreach GRP GLST
(setq GDATA (entget (car GRP)))
(foreach ITM GDATA ; step through the edata
(if (and
(= (car ITM) 340) ; if the item is a entity name
(eq (setq NAM (cdr ITM)) ENT) ; and the ename being looked for
(setq NLST ; store the ename and name
(if NLST
(append NLST (list (cons (car GRP) (cdr GRP))))
NLST
; MAIN PROGRAM
(if (and ; Are we in plan view?
(equal (car (getvar "viewdir")) 0 0.00001)
(equal (cadr (getvar "viewdir")) 0 0.00001)
(> (caddr (getvar "viewdir")) 0)
(progn
(prompt "\nSelect lines to be EXPLODED: ")
(Setq FLTR '((-4 . "<AND")
(-4 . "<OR") ; filter for mtext and text
(0 . "MTEXT")
(0 . "TEXT")
(-4 . "OR>")
(-4 . "<NOT")
(102 . "{ACAD_REACTORS") ; and not leader text
(-4 . "NOT>")
(-4 . "AND>")
GLST (acet-txtexp-grplst) ; Get all the groups in drawing
GDICT (if GLST
SS (ssget); FLTR)
CNT 0
;; filter out the locked layers
(if SS
(setq SS (car (bns_ss_mod SS 1 T)))
) ;if
;; if we have anything left
(if SS
(progn
(setq CNT 0) ; Reset counter
(while (setq ENT (ssname SS CNT)) ; step through each object in set
(and
GLST ; if groups are present in the drawing
(setq GNAM (acet-txtexp-getgname ENT GLST)) ; and the text item is in one or more
(foreach GRP GNAM ; step through those groups
(command "_.-group" "_r" ; and remove the text item
(cdr GRP) ENT ""
(setq TBX (acet-geom-textbox (entget ENT) 0)) ; get textbox points
(setq TBX (mapcar '(lambda (x)
(trans x 1 0) ; convert the points to WCS
TBX
(setq PTLST (append PTLST TBX)) ; Build list of bounding box
; points for text items selected
(setq CNT (1+ CNT)) ; get the next text item
); while
(setq PTLST (mapcar '(lambda (x)
(trans x 0 1) ; convert all the points
) ; to the current ucs
PTLST
(if (setq ZM (acet-geom-zoom-for-select PTLST)) ; If current view does not contain
(progn ; all bounding box points
(setq ZM
(list
(list (- (caar ZM) (acet-geom-pixel-unit)) ; increase zoom area by
(- (cadar ZM) (acet-geom-pixel-unit)) ; one pixel width to
(caddar ZM) ; sure nothing will be lost
(list (+ (caadr ZM) (acet-geom-pixel-unit))
(+ (cadadr ZM) (acet-geom-pixel-unit))
(caddr (cadr zm))
(if (setq vpna (acet-currentviewport-ename))
(setq vplocked (acet-viewport-lock-set vpna nil))
);if
(command "_.zoom" "_w" (car ZM) (cadr ZM)) ; zoom to include text objects
(setq VIEW (acet-geom-view-points)
TMPFIL (strcat (getvar "tempprefix") "txtexp.wmf")
PT1 (acet-geom-midpoint (car view) (cadr view))
PT2 (list (car PT1) (cadadr VIEW))
(if (acet-layer-locked (getvar "clayer")) ; if current layer is locked
(progn
(command "_.layer" "_unl" (getvar "clayer") "") ; unlock it
(setq LOCKED T)
(command "_.mirror" SS "" PT1 PT2 "_y"
"_.WMFOUT" TMPFIL SS "")
(if (findfile tmpfil) ; Does WMF file exist?
(progn
(command "_.ERASE" SS "") ; erase the orignal text
(setq ss (acet-wmfin TMPFIL)) ; insert the WMF file
(command "_.mirror" ss "" PT1 PT2 "_y")
) ;progn
) ;if
(if LOCKED
(command "_.layer" "_lock" (getvar "clayer") "") ; relock if needed
) ;if
(if ZM (command "_.zoom" "_p")) ; Restore original view if needed
(if vplocked
(acet-viewport-lock-set vpna T) ;re-lock the viewport if needed.
);if
(prompt (acet-str-format "\n%1 object(s) have been exploded to lines." CNT))
(prompt "\nThe line objects have been placed on layer 0.")
(prompt "\nView needs to be in plan (0 0 1).")
);if equal
(acet-error-restore) ; Retsore values
(princ)
(princ)
