Hi,, guys any body can help me if how can i translate this details from this cad to english and also give the step or procedure if how i translate its.
Thank you...
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
Welcome to the Autodesk Community!
I assume that what you are trying to do is to convert from Arabic text to English text. I am not sure there is any automatic way to do this. I opened your drawing and many of the text styles refer to fonts (Arabic) that I don't have on my system so there isn't much for me to play with here. Is it possible to do a Find/Replace?
You are welcome to attach some fonts (SHX) files if you would like me to explore this issue some more.
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Just a shot in the dark, but if you have the right fonts (I don't) maybe try:
