Message 1 of 30
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
HOW TO SEPARATE OBJECTS IN LINE TYPE AND ARC TYPE OBJECTS ..... AND AT THE END INFORM A HEIGHT TO ADD THE TEXT WITH THE LINEAR DIMENSION ON THE LINES AND ON THE OBJECTS ARCHED WITH THE LENGTH AND THE RAY.
THANK YOU FOR HELP !!!
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;********************Soma comprimento********************** ;********************************************************** (defun c:ADD (/ ang1 ang2 comp ctd ent old-error-sl pt1 pt2 rad raio sel sname soma ss tipo) (setvar "cmdecho" 0) (defun @Error_sl (msg) (command "._regen") (setq *error* old-error) (print "*Comando cancelado*") (setvar "cmdecho" 1) (princ) ) (defun @selecao () (print "ADD LINHAS") (setq ss (ssget)) (if ss (progn (setq ctd 0) (repeat (sslength ss) (setq sname (ssname ss ctd)) (setq ent (entget sname)) (setq tipo (cdr (assoc 0 (entget (ssname ss ctd))))) (@soma) (setq ctd (1+ ctd)) ) ) (alert "Nenhuma OBJ selecionada !!!") ) ) (defun @individual () (while (setq ss (entsel (strcat "\nADD LINHAS :"))) (if ss (progn (setq sname (car ss)) (setq ent (entget (car ss))) (setq tipo (cdr (assoc 0 ent))) (redraw sname 3) (@soma) ) ) ) ) (defun @soma1 () (cond ((or (= tipo "PLINE") (= tipo "LWPOLYLINE") ) (progn (command "area" "o" sname) (setq soma (+ soma (getvar "perimeter"))) ) ) ((= tipo "LINE") (setq pt1 (cdr (assoc 10 ent))) (setq pt2 (cdr (assoc 11 ent))) (setq soma (+ soma (distance pt1 pt2))) ) ) ) (defun @soma2 () (cond ((or (= tipo "CIRCLE") (= tipo "SPLINE") (= tipo "ELLIPSE") ) (progn (command "area" "o" sname) (setq soma (+ soma (getvar "perimeter"))) ) ) ((= tipo "ARC") (setq raio (cdr (assoc 40 ent))) (setq ang1 (cdr (assoc 50 ent))) (setq ang2 (cdr (assoc 51 ent))) (if (< ang1 ang2) (setq rad (- ang2 ang1)) (setq rad (+ (* 2 PI) (- ang2 ang1))) ) (setq comp (* raio rad)) (setq soma (+ soma comp)) ) ) ) (setq old-error-sl *error*) (setq *error* @Error_sl) (setq soma 0) (if (not old-sel) (progn (initget "S I") (setq sel (getkword "\nTipo de seleção (Seleção / Individual) : ")) (if (not sel) (progn (setq sel "S") (setq old-sel "S") ) (setq old-sel sel) ) ) (progn (initget "S I") (setq sel (getkword (strcat "\nTipo de seleção (Seleção / Individual) <" old-sel ">: "))) (if (not sel) (setq sel old-sel) (setq old-sel sel) ) ) ) (cond ((= sel "S")(@selecao)) ((= sel "I") (progn (@individual) (command "._regen") ) ) ) (if soma (progn (alert (strcat "Distância acumulada: " (rtos soma 2 4))) (print (strcat "Distância acumulada: " (rtos soma 2 4))) ) ) (setvar "cmdecho" 1) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (PRINC)
Edited by
Discussion_Admin
