Try this....
(defun c:Rename_Layer ( / Lay_name)
(vl-load-com)
(vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
(setq Lay_name (vla-get-name layer))
(if (= Lay_name "ME-DR-DRAIN-RD1-pnt")
(progn
(vla-put-name layer "ME-DR-DRAIN-RD-pnt")
(vla-put-description layer "ROOF DRAIN")
(if (= Lay_name "ME-DR-FITTING-EL1-pnt")
(progn
(vla-put-name layer "ME-DR-FITTING-EL-pnt")
(vla-put-description layer "ELBOW")
(if (= Lay_name "ME-DR-FITTING-RD1-pnt")
(progn
(vla-put-name layer "ME-DR-FITTING-RD-pnt")
(vla-put-description layer "RISER DOWN")
(if (= Lay_name "ME-DR-FITTING-RWS1-pnt")
(progn
(vla-put-name layer "ME-DR-FITTING-RWS-pnt")
(vla-put-description layer "RAIN WATER STACK")
(if (= Lay_name "ME-DR-PIPE-RWP-lin")
(progn
(vla-put-name layer "ME-DR-PIPE-RWP-lin")
(vla-put-description layer "RAIN WATER PIPE")
(if (= Lay_name "ME-DR-TEXT")
(progn
(vla-put-name layer "ME-DR-TEXT")
(vla-put-description layer "TEXT")
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
