How to rename for layera name and based on layer name description
Hello Dear Friends,
How to rename for layera name and based on layer name description also need to update.
kindly find the attached cad drawing and excel file for your reference. any one know plz send me.
Amar
dbhunia
Try this....
(defun c:Rename_Layer ( / Lay_name)
(vl-load-com)
(vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
   (setq Lay_name (vla-get-name layer))
   (if (= Lay_name "ME-DR-DRAIN-RD1-pnt")
	(progn
	   (vla-put-name layer "ME-DR-DRAIN-RD-pnt")
	   (vla-put-description layer "ROOF DRAIN")
   (if (= Lay_name "ME-DR-FITTING-EL1-pnt")
	(progn
	   (vla-put-name layer "ME-DR-FITTING-EL-pnt")
	   (vla-put-description layer "ELBOW")
   (if (= Lay_name "ME-DR-FITTING-RD1-pnt")
	(progn
	   (vla-put-name layer "ME-DR-FITTING-RD-pnt")
	   (vla-put-description layer "RISER DOWN")
   (if (= Lay_name "ME-DR-FITTING-RWS1-pnt")
	(progn
	   (vla-put-name layer "ME-DR-FITTING-RWS-pnt")
	   (vla-put-description layer "RAIN WATER STACK")
   (if (= Lay_name "ME-DR-PIPE-RWP-lin")
	(progn
	   (vla-put-name layer "ME-DR-PIPE-RWP-lin")
	   (vla-put-description layer "RAIN WATER PIPE")
   (if (= Lay_name "ME-DR-TEXT")
	(progn
	   (vla-put-name layer "ME-DR-TEXT")
	   (vla-put-description layer "TEXT")
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Dear Bhunia,
Tt is working Thanks so much.
Amar
