How to remove Model (1) from the end of a PDF
Camatties1984
Camatties1984
Here is a  .bat program I wrote to remove Model (1) from the end of a pdf. For some reason AutoCAD loves putting it in the file name.
rename "* model (1).pdf" "* "
rename "* model" "* "
for /f "tokens=* delims= " %%i in ('dir /b/s/A-d') DO (
  if "%%~xi" == "" rename "%%~fi" "%%~ni.pdf"
I'm sure someone else has had this problem.
jdiala
Here is mine
(defun C:rempdf (/ dir)
  (if
    (setq dir (LM:browseforfolder "Browse for a folder on where the PDF's are located. " nil 512))
    (mapcar
      (function
        (lambda (x)
          (cond
              (vl-string-search "Model (1)" x)
              (vl-file-rename
                (strcat dir "\\" x)
                (strcat dir "\\"
                  (vl-string-subst "" " Model (1)" x)
              (vl-string-search "-Model" x)
              (vl-file-rename
                (strcat dir "\\" x)
                (strcat dir "\\"
                  (vl-string-subst "" "-Model" x)
      (vl-directory-files dir "*Model*.pdf")
(princ)
;;------------------=={ Browse for Folder }==-----------------;;
;;  Displays a dialog prompting the user to select a folder.  ;;
;;  Author: Lee Mac, Copyright © 2013 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  msg - message to display at top of dialog                 ;;
;;  dir - root directory (or nil)                             ;;
;;  flg - bit-coded flag specifying dialog display settings   ;;
;;  Returns:  Selected folder filepath, else nil.             ;;
(defun LM:browseforfolder ( msg dir flg / err fld pth shl slf )
    (setq err
        (vl-catch-all-apply
            (function
                (lambda ( / app hwd )
                    (if (setq app (vlax-get-acad-object)
                              shl (vla-getinterfaceobject app "shell.application")
                              hwd (vl-catch-all-apply 'vla-get-hwnd (list app))
                              fld (vlax-invoke-method shl 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) msg flg dir)
                        (setq slf (vlax-get-property fld 'self)
                              pth (vlax-get-property slf 'path)
                              pth (vl-string-right-trim "\\" (vl-string-translate "/" "\\" pth))
    (if slf (vlax-release-object slf))
    (if fld (vlax-release-object fld))
    (if shl (vlax-release-object shl))
    (if (vl-catch-all-error-p err)
        (prompt (vl-catch-all-error-message err))
        pth
(vl-load-com)
