How to open the subfolder What i Mistake
jaimuthu
Message 1 of 10
jaimuthu
here i attached lisp code i want open the subfolder
(defun c:aus ( / projCode baseFolderPath projectFolderPath jaiFolderPath)
  ;; Prompt user for project code (numbers only)
  (setq projCode (getstring "\nEnter project code (numbers only): "))
  ;; Check if the entered project code is not empty
  (if (not (zerop (strlen projCode)))
    (progn
      ;; Define the base folder path
      (setq baseFolderPath "D:\\MUTHU\\")
      ;; Check if the base folder path exists
      (if (not (vl-file-directory-p baseFolderPath))
        (progn
          (princ (strcat "\nBase folder path does not exist: " baseFolderPath))
          (princ)
        (progn
          ;; Define the path pattern to search for the project folder
          (setq projectFolderPath (strcat baseFolderPath "*" projCode "*"))
          ;; Get the list of folders in the base directory
          (setq folderList (vl-directory-files baseFolderPath "*.*" 1))
          ;; Find the project folder
          (setq projectFolderFound nil)
          (foreach folder folderList
            (if (and (vl-string-search projCode folder)
                      (vl-file-directory-p (strcat baseFolderPath folder)))
              (progn
                (setq projectFolderPath (strcat baseFolderPath folder "\\"))
                (setq projectFolderFound t)
          ;; If project folder is found, search for "JAI" subfolder
          (if projectFolderFound
            (progn
              ;; Check if the "JAI" folder exists
              (setq jaiFolderPath (strcat projectFolderPath "JAI\\"))
              (if (vl-file-directory-p jaiFolderPath)
                (progn
                  (princ (strcat "\nOpening: " jaiFolderPath))
                  (startapp "explorer" jaiFolderPath)
                (princ "\n'JAI' folder not found.")
            (princ "\nProject folder not found.")
    (princ "\nNo project code entered.")
  (princ)
Replies (9)
Message 2 of 10
Kent1Cooper
What happens that indicates a mistake?  What does not happen?  Are there any messages?  Etc., etc.
Kent Cooper, AIA
Message 3 of 10
paullimapa
found following 2 problems:
1. the following lists files and not folders:
change to one of these to list folders:
(setq folderList (vl-directory-files baseFolderPath "*.*" -1)) ; lists folders
; or use nil = "*.*"
(setq folderList (vl-directory-files baseFolderPath nil -1)) ; lists folders
2. the following places the "\\" in the wrong location:
"\\" should be placed before JAI like this:
(setq jaiFolderPath (strcat projectFolderPath "\\JAI"))
Paul Li
IT Specialist
@The Office
Message 4 of 10
jaimuthu
ITS NOT WORK
    (progn
        (progn
          (princ)
        (progn
              (progn
            (progn
                (progn
  (princ)
Message 5 of 10
Kent1Cooper
@jaimuthu wrote:
ITS NOT WORK
Never say only that much.  See Message 2.
Kent Cooper, AIA
Message 6 of 10
komondormrex
check this
(defun c:aus (/ base_folder project_code jai_folder)
	(setq base_folder "D:\\MUTHU\\")
  	(if (= "" (setq project_code (getstring "\nEnter project code (numbers only): ")))
		(if (null (vl-file-directory-p base_folder))
			(princ (strcat "\nBase folder path does not exist: " base_folder))
			(if (vl-file-directory-p (strcat base_folder project_code))
				(if (vl-file-directory-p (setq jai_folder (strcat base_folder project_code "\\" "jai")))
					(startapp "explorer" jai_folder)
	(princ)
Message 7 of 10
jaimuthu
not work
Message 8 of 10
paullimapa
sine line 31 you've already added "\\"
then line 41 you don't need to add "\\":
instead just include "JAI":
            (setq jaiFolderPath (strcat projectFolderPath "JAI"))
Paul Li
IT Specialist
@The Office
Message 9 of 10
komondormrex
@jaimuthu wrote:
not work
can't be
Message 10 of 10
Kent1Cooper
@jaimuthu wrote:
not work
That is never enough information!
Kent Cooper, AIA
