Check if layout tab exists before running commands
emilio24DRY
emilio24DRY
I have the following code:
(defun ECR:setTab ( TAB / )
;; !!IMPORTANT!! TAB NAMES ARE CASE SENSITIVE OR ELSE IT DOESN'T WORK
;; CHANGE TABS AND DO ZOOM EXTENTS ON THAT TAB
	(cond
		((member TAB (layoutlist))
			(setvar "ctab" TAB)
			(command "zoom" "extents")
		);LAYOUT EXISTS
		(t
			(princ (strcat "\n-\n" TAB " does not exist to be set (setTab). Note that this function is case sensitive.\n-\n"))
		);ELSE
	);COND
(princ)
Do I have to change it to the following code to allow "Model" to pass through it since (member "Model" (layoutlist)) returns nil. Why is this happening? Does layoutlist only check for tabs other than Model?
(defun ECR:setTab2 ( TAB / )
	(cond
		((or (member TAB (layoutlist)) (eq TAB "Model"))
			(setvar "ctab" TAB)
		);LAYOUT EXISTS
		(t
		);ELSE
	);COND
(princ)
or is there another way that allows "Model" to pass through?
Thanks!
marko_ribar
Practically you answered your question yourself... Now mark your answer as a solution...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Kent1Cooper
Yes, "Model" is not a Layout -- those are a function of Paper Space.  One could say it's misleading that the CTAB System Variable "works with" a space that is not actually a "tab" in Paper Space, as named Layouts that it also works with are, but it is a tab along the bottom edge of the drawing.
By the way, you can make it not case-sensitive if you like:
  ((or (member (strcase TAB) (mapcar 'strcase (layoutlist))) (eq (strcase TAB) "MODEL"))
Kent Cooper, AIA
emilio24DRY
@Kent1Cooper
Thanks! I will add strcase to not make it case sensitive. How does the following code work?
Kent1Cooper
@emilio24DRY wrote:
.... How does the following code work?
First thing to try:  Read about it in the AutoLisp Reference.
Kent Cooper, AIA
marko_ribar
(strcase) may not always be a solution especially if you are working with non English alphabet... Check (xstrcase) function that accepts only single argument - string and always turns string to uppercase letters... But also I don't know for which range it works... Chinese characters don't have lower/upper cases - they have only signs which are always uppercases... Also, you have 2 versions of *.lsp files that must be preloaded to work (it should work well for both AutoCAD and BricsCAD) - it's called "lstrcase.lsp" and it has 1118 pairs of upper/lower signs that cover all that is available from letters in Windows... "lstrcase.lsp" with it's function "lstrcase" accepts string and argument t/nil - "t" is for lowering and "nil" is for uppering letters... Here is the link for dedicated topic on theswamp.org, but you must be logged to download file(s)...
https://www.theswamp.org/index.php?topic=55041.msg621655#msg621655
